Hi Guys,
I just took my GTR for a drive around the block,My oil gauge drop when i give it some gas, Frist i thought mayb the gauge is playing up(Greddy oil pressure Gauge).
But now i think it's a more serious problem.
But on idle and driving normal it seems to be fine, But when u cane it it drops, What could this be some info would be Great.
Cheers.
Edited by Rav
https://www.sau.com.au/forums/topic/199477-oil-pressure-problem/
Hmm, bit suss hey. My R32 GT-R also displays rather low oil pressure on the standard guage after some enthusiastic driving.
I think it has something to do with the lower viscosity of the oil after it gets really hot when driving hard. There will be less pressure because the oil flows easier.
Might also have something to do with the oil control issues in the RB26. poor oil return to the sump. Check this thread:
http://www.skylinesaustralia.com/forums/Oi...ui-t110680.html
Other than that have some other guys post up their oil pressure readings and refer to the engine manual specs.
Its not my standard gauge it a greddy oil pressure, and its go's up normaly but ones the boost comes in hard, the pressure drops fast.
ive noticed the stock gauge to have a delay on it compared to a good aftermarket one.
but i would be a bit worried if the oil pressure drops when applying load. mine sits on about 2 bar for idle and always rises up on acceleration, normally up to 5 or 6 bar. (blitz electronic gauge)
does it blow smoke? probably best to get a compression and leak down test done.
Edited by Sambo33
I wouldn't have thought low compression would cause a drop of oil pressure like that.
Check your oil level immediately, if it's low it could be pumping excessive oil into the head at higher RPM.
DO NOT, I repeat, DO NOT keep driving it if this is happening. It could cost you a motor.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
