Guys/Girls,
I have recently bought a Arias Piston Kit but I have received a called from the workshop stating that one piston is different to the other 5.
Apparantly that piston is exactly the same size as the rest, just has a lip or something at the edge.
The workshop says that they can still install it but they want the go-ahead from me.
Is this correct or am I meant to take it back to where I bought it from and get another kit?
Danny
https://www.sau.com.au/forums/topic/199478-piston-kit/
That I'm not too sure about..
They're not opened until 2nd of Jan (Wed) so I gotta wait until then.
All I know is that the bores are all the same, only problem is that one has a lip or something around it..
https://www.sau.com.au/forums/topic/199478-piston-kit/#findComment-3557133
I wouldn't use a suss piston , it will cost you heaps to fix later .
dalostcambo, whats the piston to bore clearance ? I think Arias specify 4thou, a little to rattly and blowby for a road car but good for a track car.
Adriano, different weight piston will not effect any of the above unless the piston was different size, different weight pistons will unbalance the motor though, I may say that they are almost always different weights ( only by a small fraction, mostly unnder one gram) this is why you weigh the pistons and the rods, then use a heavier rod with a lighter piston to balance . Its best to balance them all with the crank, flywheel and cluth on a high reving engine.
https://www.sau.com.au/forums/topic/199478-piston-kit/#findComment-3559325
Ahh... Went down to the workshop yesterday, it was the second ring without a groove on the lip (so confusing over the phone)..
Thanks for the help!
Took the ring back and got it swapped over for another.
Can't wait to get the beast back now! =D
https://www.sau.com.au/forums/topic/199478-piston-kit/#findComment-3562347
yeah there seems to be a period when arias upgraded the rings, it must have snuck through some how.
https://www.sau.com.au/forums/topic/199478-piston-kit/#findComment-3562484
no offence mate, but if your engine builder was going to put 1 wrong ring in I think you should take it somewhere else.....
Ring was EXACTLY the same as the others, just didn't have the groove at the edge of the ring.
This is why they called me, to see if they have the okay to go ahead with it or wait..
https://www.sau.com.au/forums/topic/199478-piston-kit/#findComment-3563993
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
