well i put one on my car (a jap one for $30-40) and it came with a special gasket, not a goo one but a proper gasket. i cleaned the old gummed up surface on the car so it was like chrome!!! and well so far no leaks... and i even skipped that 6mm bolt that doesnt line up...
i did a track day the other day and no issues what so ever...max temp of water was 105degC
One of the holes wont line up but it can be elongated to fit. The twincam pump on the Rb25det has a higher flowing impellor/the same as the one used in the Rb30det. The N/a unit wont flow as much, but is ok if your not using it for racing. N1 pumps have a slightly different design which prevents cavitation at higher rpm
You mean RB30ET?
I need a new pump but my engine won't be seeing any more than 7000rpm, can I get away with a standard RB20 water pump? (also don't want to modify any holes etc to make it fit) In case it helps, I do enjoy a good burnout :blush:
