just done my new clutch by myself with two trolley jacks and some wood lol (it was a heavy box):) took a day tho
but now i should bleed my clutch
question is should i bleed from slave?or master?or both in order?
used to be longest line bleed first? :)
hehe i will be bleeding by myself as usual too (with my magyver tricks):(
https://www.sau.com.au/forums/topic/199484-bleeding-the-clutch/
To quote simon on a thread that i put up a couple months ago.. works a treat!
u can bled clutch yourself. crack the bleed nipple on the slave, push the clutch peddle in, it will stay on the floor, close the nipple and pull the peddle back out.. do this several times and top fluid up.
done :)
