if its from a 32, its a silvertop.
banjo bolts are special bolts which pass fluid through them, they through an eyelet fitting which has a solid steel line going to it, there are three on the turbo, two water feeds and an oil feed.
nothing needs to be modded, the turbo will fit straight up.
thanks guys, the RB25 Neo turbo on RB20 problems was solved... once again, thanks guys
now, i have some more questions relating to fitting this turbo on my RB20det with usual mods..
- pod filter
- Hybrid FMIC
- 3" turbo back with hiflow cat
- walbro 255 fuel pump
- manual boost cont. runing 13psi
- standard ecu
ok, if i fitted this RB25 Neo turbo on my RB20det,
- what else need to be done?
- can i run this set up with my stock ecu?
- should i remapping my stock ecu? (dont have enough budget to buy stand alone computer yet)
cheers
Edited by subie
- pod filter
- Hybrid FMIC
- standard ecu
cheers
Yes i think you should remap your ECU if you don't have the finances to buy an aftermarket ECU.
A mate of mine ( Limpus ) is running a HKS turbo in his RB20det with a Dr Drift remapped ecu. He'll have great knowledge on that. Do that first then save up some money and get a Power FC or something similiar.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
