Im fitting Apexi 270/11.4mm cams to my new RB26 head. I have releived the casting, cut valves, new guides etc etc.
Now come time to set the valve clearances the apexi cams use significantly smaller base circle.
The old Poncams had a base circle of 32.00mm which is obviously same as the OEM cam.
The New Apexi cams have a base circle of 30.40mm.
Majority of my existing shims are 2.80mm which is fine.
However the base circle is 1.6mm smaller than the original meaning I have to increase all my shim sizes by approx 1.6mm.
1.6mm on top of the original 2.80 is 4.40mm. The largest shims Ive seen are those CRD are selling which are 4.30mm.
So im asuming I have a few options, make my own shims to suit that are roughly 4.40mm (obviously made to exact size I calculate) OR........ im open to suggestions on the situation.
Thanks In advance Brad.
do apexi make shims to suit? like tomei do with their cams...
No not that I have been able to find. Its only .1mm larger than those that CRD are selling and I have the equipement to grind my own shims from a suitable material so its looking like ill take that path as the tomei shim kits start getting expensive.
hi mate you will need to buy a set of new buckets for them cams. tomei sell sets that are 1mm and 2mm thicker ..
http://www.nengun.com/tomei/valve-lifters
Edited by rockabilly
Thanks Proengines, Ill be speaking to chris about doing this.
Any idea what thickness shim you went up to??
Im running apexi retainers which seem to have a much taller recess for the shim, obviously to aid with holding the thicker shim in position.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
