This is just from memory so it could be slightly wrong
push the TV button on the left panel near the bottom
on the screen push the far r/h button to scroll thru something like this
TV(auto) -> TV(manual) -> AV1 -> AV2 -> back to the start
any probs & I'll physically check
good luck!
correct, but AV2(called VTR2 I think) will not display unless something is plugged into it, you will probably need the original factory stereo to get a sound from AV1. Most modern head units have the input plug anyway, with far better sound than the clarion unit, and no need for band expanders.
good luck!
Looks good! Thanks!
Errr... Chook, correct me if I am wrong, but do you mean that we can leave original Xanavi Double DIN unit in place , replace only factory radio (strereo) and connect Xanavi Head unit to it ?
  • 1 month later...
That would be interesting... can that be done?
Do you mean that you want to use the AV inputs on the front of the xanavi and play this through an aftermarket headunit ? if someone could pin-out the right wires on the back it should be possible, as well as play cd's on the xanavi. But considering the low price of quality headunits with front inputs these days, it wouldnt be worth the hassle.
That's true. I thought there might be some use to replacing just the single-DIN radio/headunit, but I guess you would then lose the capability to control the 6-stacker in the boot... best then I guess to either do the TV conversion & take advantage of that LCD display (:(http://www.skylinesaustralia.com/forums/St...Tv-t203961.html) or get rid of it altogether.
Edited by DaveB
On a related topic, in researching the connections on the back of the Xanavi centre-console unit itself, someone somewhere posted a pic' of the rear of the centre console Xanavi cluster on here a while back... does anyone have a link to it as I can't find it in a few different searches?
A stacker can't compare with an mp3-dvd head unit, not to mention the sound improvement over the factory head unit. Got rid of mine as soon as possible.
Dont know where that pic is, there are quite a few dozen wires going into back of the xanavi, did you want to compare the air-con connections ?
Actually I mainly wanted to know if the brackets for the Xanavi were the same as for the 3-DIN setup with the stand-alone climate control unit or if they were different. These are the brackets I mean (not sure if these are standard or Xanavi):
brackets are different as the exnavi unit is wider than the stock din size it is ofset to suit the exnavi.the ones u have in pic are 3 din ones.regards mike
thanks Mike :laugh: I think you predicted early on that I'd end up swapping out my Xanavi
Ah, I am afraid, it's time for me to clarify something. What does actually Xanavi unit do ? Or, I think I'd better put it that way, where is the amplifier located (if you can call that thing "an amplifier") ? Does Xanavi have an built-in amplifier or single din stereo does the job ?
Basically, what I want to get, it's quite simple - I want to keep Xanavi unit and use it's LCD screen to play movies, use it for climate control system ,etc, but I also want to swap single-din stereo and put something better instead, probably even MP3/dvd player or just a good single-din stereo. I'd also like to keep existing functionality, as volume control, etc on a steering wheel.
Am I asking too much ? :cheers:
No amplifier, just a screen, aftermarket single din stereo will be a good upgrade. You will lose the ability to play CD's on the Xanavi and you might lose the functionality of the steering volume unless you are talentled with electronics and can integrate it with your aftermarket one somehow.
Losing an ability to play CDs on the Xanavi is not a big deal as a single din stereo will do the job, but I'd like to keep functionality on a steering weel. Ahhhrrr :cheers:
Just wonder if anyone managed to connect an aftermarket stereo and keep that functionality at the same time ?
Losing an ability to play CDs on the Xanavi is not a big deal as a single din stereo will do the job, but I'd like to keep functionality on a steering weel. Ahhhrrr :teehee:
Reference on the ALPINE site. scroll down to ' Steering remote ready ', talks about using the factory steering buttons. http://www.alpine.com.au/support/glossary.asp
Is the head unit clarion ? Could be compatable with an aftermarket Clarion ?
Either way, if you talk to the right car sound people (not JB), it is highly likely you can keep them working.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
