thing looks insane, but u gotta fill those z tune guards out more.
love the bonnet
btw are those Z tune guards genuine?
Nope, definatly not, they look like a cheap knock off with a added vent on the side!
Your original gaurds looked much better!
nice ride buddy
how do those seat covers fit??? i was thinking of getting a seat off yahoo auctions
Hey man.. soz.. just stumbled over ur tag!
ahha it's sik :P
made this 4 u man
[url="http://s227.photobucket.com/albums/dd220/MengYeng/?action=view&current=turbosmallcopy.jpg"][img=http://i227.photobucket.com/albums/dd220/MengYeng/turbosmallcopy.jpg][/url]
    • Found it thanks, the front tie rod end should be torqued to 40nmish
    • Ok I thought my allow had a flat back but it does have grooves for the spacer nut/ no cutting needed   bolt and nut sticking out from the spacer around 12mm and the groove is around 24mm so all good   appreciate the help chaps
    • Back in 2016 bought a set of front and rear bracket set and changed all 4 corner discs and caliper   i was checking the car and seen rust like or in another word crumbled part of the bracket which came off with a air blow   is this normal? This had happened in two areas and car from 2016 has mostly been in garage/ doing less than 2000 miles over past 8 years or so pic with areas highlighted in red   https://ibb.co/NtmWXZt   also anyone knows the torque spec for the bracket as want to retorque them, one bolt had come off half way !
    • So if I was to spend 400r money and remember I am only here because I need 4 doors because of an incoming kid otherwise I would be looking at a lexus RCF what am I loosing out on other than fuel economy but gaining in power and space / V8 sound on Chrysler 300c STR Vs nissan 400r?, I will admit that buying the VE bomadore was an eye opener into build quality compared to Jap cars... https://www.carsales.com.au/cars/details/2020-chrysler-300-srt-core-auto-my20/SSE-AD-18201088/ but this one is on the same money...
    • If you're friendly with a workshop that has a large scraps bin you can always ask to dispose of there. Otherwise theres always the places like sims metal etc depending where you are at https://recyclingnearyou.com.au/cars
