i filled our car yesterday to the first click of the pump and headed out for a drive . i was 40 deg in adelaide yesterday and we had been driving for about a hr and was heading home when i could smell fuel vapours in the cab of the car.
car also seemed to be running really rich as well when i got it home i undid the fuel cap and there was so much pressure in the tank it actually blew the cap out of my hand and the vapour that was comming out of the tank was very hot .
i come to the conclusion that the pressure in the tank must have been forcing more fuel thru the injectors under so much pressure hence the running rich and fuel smell. also the petrol gauge was reading wrong when driving but when i realeased the cap it went back to where it should be reading.
so im guessing the fuel cap is not venting properly and not realsing pressure like it should be . anyone else struck this prob b4
cheers dean
https://www.sau.com.au/forums/topic/199522-faulty-fuel-cap/
The tank should only really pressurize when stand still. The fact yours is, while running is an issue.
Punch that SAU search button like a naughty 9 year old, for the in / out / trigger layout, check to make sure your charcoal cannister is doing its job.
https://www.sau.com.au/forums/topic/199522-faulty-fuel-cap/#findComment-3556965
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
