hey all just a coulple of quick questions bout my r33
1. i just bought an alarm for it but i need to install a doorlock actuator for my drivers door would i be nuts in buyin a genuine door lock actuator ex. japan brand new for 130 bucks or should i just buy a cheap ass one and try and fit it
also how do you wire an alarm to a turbo timer it is quite hard but i just need a little bit of direction
2.does any one know who i can call in melb to rebuild one of my JIC adjustble coil overs
3. is there any where i can get a din size mount to go in the spot under my cdplayer or do i have to buy a dvd player
4.does any one know how to set a blitz dual boost controller i didnt get instructions!!
if some one could help me with at least one of these i would be appreciative
Pm me the second question so i wont forget, i will get the address of where my Tein suspension was reco'ed. They did a good job and were not too expensive. You should do the pair, ie: if one of the rears blew, do both rears so that they will be matched.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
