Rb20 Power Proplems
TOSHI, CEFFIE on these forums.
Can both do this sort of shit for these sort of dollars.
the fact is, if it's using stock Injectors, stock AFM, they can use one of their generic chips that they would have.
I'm sure both have the ROMs to match an RB20 with (eg) 12 psi, stock injectors, afm and stock turbo and then another which has the above but with rb25 turbo... etc..
and they can both remove the speed limiter and raise rev limit if you want..
Just drop the guys a PM and ask some questions.
they are both very heplful
  • Replies 49
Guest trikdoutvl
huh... i dont have a speed limiter
on a unrealated note....... do all skylines have a beeping alarm when 1 of ur indicators stop working?? cause my indicator stopped workin n when i put the indicator on the car starts beeeping, neva didd that before i had the rb20 motor
Hmm that’s interesting.
Wonder why the auto had it but not the manual, maybe just as a warning as the auto wouldn’t stall like the manual if you accidentally put it in reverse and forgot about it.
I think I vaguely remember my cousins 93 R32 auto having a reverse beeper thingy...
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
