I have the motor in and carbies ready to go. The mechanical pump of my L24 fits into the 260 but will this supply enough fuel, or do i need a holly blue & regulator. Is anyone else running a 260 or280 and what fuel set up are you using? Please send info.
https://www.sau.com.au/forums/topic/199568-260z-twin-2-sus-in-my-c210/
Thanks for the generous offer ghostrider, I'm in Mandurah. Ph 08 95818997. 6.30 pm is a good time to ring. Again thanks Rick. I have a suspicion we're not in the same state, could be a long drive for a p/gauge.
Hey mate. I am running twin SU's on an L26 and my Peirburg electronic fuel pump is maintaining a steady PSI right through the rev range. While I am having plenty of other problems, the fuel pump isn't one of them.
Have also seen good results with the Japanese Toiko pumps or even the stock electronic fuel pump from the 280zx. Good luck with it.
Hi coupe72001 and thanks for the reply.
Just a couple more questions. With your Peirburg pump are you using a regulator or is it naturally about 6 psi, I've read that's about the optimum pressure.
Also do you have the mechanical pump still in the mix of things. ie tank--filter--elec pump--mech pump --regulator, carbs.
Finally does the Peirburg make much noise and is it like a holly blue meaning it has to be lower than tank or does it suck fuel rather than gravity feed. Sorry for so many questions but this is the last piece of the puzzle and currently I'm stumped regarding what setup to use. Thanks Ricky. One more thing, are you using the fuel return line?
Ok...
1. I had a regulator, but my fuel guy threw it out! Said it was unneccessary - which has probably proven to be true as the fuel PSI holds steady.
2. My electric fuel pump seemed to suck well, but to be on the safe side I mounted it below the fuel tank at the back of the car, so it is "pushing" rather than "sucking".
3. It's noisy as all hell, which is good because I know when it's broken and I like noisy cars anyway.
4. I am using the same fuel line setup as the stock setup... I think.
5. I threw out the stock fuel pump. Steal a block-off plate to cover the hole from an injected car without power-steering... (maybe a 280zx or an r30???) or buy a nice billet chrome one from ebay America.
Hope that helps. I can post a few pics of my carby setup if you'd like.
For the record can anyone confirm how many PSI of fuel flow would be needed to feed twin 2' SU's. I thought it was only 3-4.
Ok...
Ok...
ithought it was only 3-4.
I'd certainly like to see some pics if it ain't a problem, and you didn't mention wether or not your using the return line.
So if your not using a regulator your pump must be a low psi 3-4 pump, maybe I should look it up on the net. Again thanks Ric. I've tried to put pics on with thread but must be doin something wrong.
I've had SU's and Webbers on L series engines before and I've only ever used the standard mechanical pump which I have been told by numerous carby tuners is more than adequate and with no pressure reg required. Is a bit more farking around with a leccy one too.
Cheers, Vaughan.
Cheers, Vaughan.
Vaughan I believe your right in what you say as I've just finished reading about an hours worth of threads, mostly American. It seems plenty of people are running just mechanicals.
The only issue I have now and hopefully someone can tell me is, i had to use my L24s or C210 78 skyline mechanical pump as the 260 one was removed. I've been reading my workshop manwell and the L24 mechanical pump, pumps around the 80 ltrs per hour.
What I need to know is, is this close to what the 240z mechanical pump can do.
Yeh rick all will be good, I have interchanged L4 and L6 pumps from all versions and as far as I am aware they are all one and the same. Good old nissan interchangability.
Sweeeet, I think this is now confirmed and I'll lay it to rest, but of course i'll let you know how it goes in practise . Thanks for the confirmation and all registered threads, your help is a... well a big help.
Cheers Rick.
Thanks Coupe72001.How's it going now, do you get good performance out of it?Are your S.U.'s 1.75 or 2'' and are they H.S series. Do you run a return line to the tank? Sorry about so many questions, just interested as mine is still a while away from running.
On the dizzy thread I've asked what induction you use,that's been answered thanks. I've just had some parts sent from England for my S.U's, got them off ebay and it took 6 days for delivery.Pretty good i thought. Cheers Ricky.
Hey Rick,
They are 2 inch from a Rover (most likely) and they are now going like the clappers. I had a poke around and it doesn't look like I use my fuel return anymore! I had forgotten that I disconnected it way back when I first swapped the carbys. I don't know if they are HS series or not, but if you tell me what to look for Ill find out.
Good work getting the carby bits promptly from the UK. I am learning to love ebay UK and US for getting some of the hard-to-find parts.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
