Aircon Regassers In Melbourne That Use Hychill Hr12 Gas
not that much work to "convert" to HR12 unless the car has already been converted to R134a. if the car still has the old R12 gas in it, then it just needs to be tested etc. Degassed and regassed with HR12.
Ill have a quick guess at around $300 mark?
Someome correct me if im wrong please
hahah, tow car... you make it sound like something normal! should get the plates, A380 or something - if it's the massive beast i'm thinking of...
did you go with Hychill refill??
Hey,
Haven't seen this before.
I've had my R32 GTR for 5 years now and have never had air con.
It was never gassed since it came over.
Where around croydon or ringwood does this regassing with hychill?
I also have got to get the pulley bearings looked at as they are very noisy.
Any suggestions on where to go?
Hey,
Hey.
The gas were talking bout is known as either Hychill or HR12.
A lot of A/C places will try to talk you out of it cos they dont know much about it themselves or have had too much R134a crap thrown at them to know any better. HR12 is essentially a natural refrigerant replacement for the old R12 systems that we have in R32's.
The HR12 works a lot better then the R134a stuff. Enough for you to cool a can in front of your air vent! it also wont corrode your A/C system like R134a does.
Sorry i dunno any places around your area that knows their stuff. I think my brother mentioned that his mechanic has it. ill find out soon.
Good luck finding a place.
I didnt really get a chance to talk to ya at the midnight cruise apart from trying to figure out where we were!. will hafta talk properly next time.
Hey.
Yeah cool, will have to chat next cruise.
If you could find out where a good place is that can do my air con let me know.
I dont mind a drive, if it gets done properly.
Cheers.
the two most reputable people is spoke to talked me out of it..... gave me the option but i ended up going R134 :happy:
Stupid A380 needed new hoses, TX valve and receiver drier been open for too long.... i wanted the a/c to be perfect so took to anything that could be suspect... lucky the conversion used xf falcon gear so its only the hoses (20ft of hose :D ) that is dear.
Attached a pic of what it should look like once finished. 10 stud FTW
Edited by URAS
As stated in an earlier post (although in 2008 lol), JNK Auto does HyChill...
I just called them up now and spoke to Tim. What a champ, he spent like 20mins chatting to me about it explaining it all. Good thing was he was honest and said he is still acquiring his licence to do ac gassing and he doesn't personally do it, his boss does (John). Shows to me he's pretty clued up even though he doesn't personally do it.
Anyway, I'm book in for next week. Their contact number is 9873 2622, located in Mitcham.
Cheers,
Andy
Edit: Quoted $132 GST inclusive for the full works (i.e. full flush, lube and dye, and recharge etc.).
Edited by AnDyStYLe
Cheers,
Andy
Excellent mate.
Will give them a call for sure. Thanks.
Ok guys, doing the whole works including fault testing, full flush, change of receiver dryer, and gass fill...
John mentioned that they is not point doing the full works if you don't change the receiver dryer as it acts as a filter. All up if all goes well it'll actually be about the $220 mark!!!
The lubricate they'll be using is Wurth Ester Oil with U/V Dye (http://www.wurth.com.au/catalogueview.asp?pdf=A04_0601.pdf). Just done some research and found positive reviews. Better than PAG oil.
Will keep you all posted...
Cheers,
Andy
Edit: Ok, now found that POE = POE Polyolester (type of oil for A/C) according to acronyms.thefreedictionary.com, so if I'm not wrong that means the Wurth Ester Oil with U/V Dye is POE which is what level323 recommends. Hope that's the case!
Edit #2: Found the MSDS for the Wurth Ester Oil with U/V Dye - http://www.wurth.com.au/msds/1892_764_334.htm
Edited by AnDyStYLe
Ok boys, update...
Ran into issues with the a/c where we found out that the a/c compressor sh!t itself... My options where either to repair, replace brand new or second hand. 1. Repair was going to be like $500, 2. Brand new $1k :P , 3. Sourced my own second hand unit for $100 :(
So anyway, I picked up the compressor on Friday morning which we only found out this morning when the original one was removed to be replaced, it was the wrong one. Needed to go back to the wreckers to exchange for the correct one...
Anyway, to cut the long story short... John/Tim from JNK Auto sorted it all out today and has done an excellent job. I am bloody wrapped!!!
All up I spent $260 to JNK and $100 on the second hand compressor. I gotta say JNK looked after me pretty well and would recommend them for sure!
Unfortunately John wasn't too keen on a "group buy" as in his past experiences, many of the people in the "group buy" ruin it for the others by not turning up. John would prefer a individual case by case like mine.
Cheers,
Andy
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
