Hi friends today am bringing somthing strang for all of you :devil:
as i posted before that i had aproblem with my rb25det like fuel cut
today i reprogramed the safc2 and set all values to 0 and before was -35
when i did this turbo start to spool 13psi in nutral am not moving just like ANTI LAG SYSTEM
and it cant continue to redline cutoff just reach till 500 rpm and hold
so guys is this ok or somthing wrong with it? :D
https://www.sau.com.au/forums/topic/199630-somthing-strang-with-turbo/
Sounds like like your ignition timing is fully advanced.
hi dear but i don`t know i didn`t change anything just the safc2 sittings
from -35 to 0 and before it was runing 7psi with -10 all rpms on safc2 it was great
but then i rised the boost to 13psi then it start kicking like fuel cut when boost come
finally i changed the safc2 to 0 so do you think its auto advanced? :blink:
Actually i would say the timing is very retarded, the base timiing may have been retarded when the SAFC was tuned to allow those -ve numbers without pinging, and now you have set them to zero.
Adriano sounds on the money.
Retarded timing = combustion isn't complete when exhaust valve is opening, allowing the turbo to spool
so dears do i need to change ecu? or cheek A/F ratios ? or git red of bleed valve?
    • I once hit my knee on an exhaust on my sisters Suzuki Sierra after she drove it her *normal* way. My knee looked like porridge for weeks. Bec and my daughters never go near this car. I can see one of my dogs losing an ear though. 🤔
    • Nice, love a good GTS-t.  IMHO the factory body kit with the 'aero' front bumper is perfect. Can't improve on it unless it's a GT-R. But it looks like you changed it to the normal bumper?
    • Easy solution to both of those. Put a split bit of garden hose on each one. Attractive and practical!
    • So I guess the next thing to do will be to discuss whether to create a new section of the forums to hold the library (boo hiss?), somewhat undoing the recent tidy up, or if there is a bolt on wiki module for Invision? (I must profess ignorance as to what has been done, what it might cost, etc. I have only briefly googled and seen discussion on adding it.) Or is a wiki even the best way to do what I'm talking about? It possibly isn't. Given that we're trying to re-display forum content, it probably needs to be presented as forum content in forum format, and a wiki would probably struggle with that. A wiki might still be the best way to do some other things, so I'll keep the idea simmering if we don't use it here. Back to the library as "part of the forums". Would we do a single new library? Or put a library thread in each section? Pluses and minuses for each of these, surely. Would we do as I originally suggested, and make the first post in the library be the total of the library, with any reply posts just being the inputs and suggestions I originally posited? Or would we allow posts to accumulate one after the other, each containing additions to the library? Maybe the first post is still an index or something. It's all sounding horribly more manual and messy than my original brain fart. But I hope there's some other good ideas floating around - because every time I come up with a new one of my own I immediately see problems with it.
    • Tips look fine to me......but Boring stuff: Legalities - Vehicle standards notes that exhausts cannot extend to a point where they could cause injury Scary stuff: Mrs cuts open her shin putting stuff in the boot (ensure you have some bandaids and shiny jewellery handy)
