Hey there forum I just have a quick question for the experts. Today I noticed that the mitsubishi sign in the middle of my cas was not spinning. I let it idle and gave it some free revs but got nothing. does this mean it is broken? The cas is suppose to spin all the time right?
https://www.sau.com.au/forums/topic/199632-about-crank-angle-sensor/
the mitsubishi symbol isn't supposed to spin. :worship:
Wow so that means my timing is basically f&^*ed cus i noticed it was spinnning the other day but I figured it was normal and noticed a bolt was missing so I replaced it and it stopped the spinning thats why i thought it was broken. So can it spinning while in place cause the timing to get stuffed?
