Yeah,
I've been watching BMI for a while now and noticed that most of the hardcore time attack monsters and the Super GT cars in Japan has this thing call CANARDS attached to the side of the front bumper.
I could sort of figured out what they are for but the question is do they REALLY work? If they do why our V8 super cars wouldn't have them on?
https://www.sau.com.au/forums/topic/199648-canards/
*apparently* at highway speeds the front is slightly more stable, but it would depend on the car i guess.
V8 supercars arent exactly the most aerodynamic things to begin with lol.
Edited by s2k12
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3557567
what are canards designed for? are they for downforce or to direct the airflow around the car more efficiently? if they are for downforce, they would probably work better at high speed (racetrack). also the front bar would have to be more rigid so the downforce didn't just flex it.
my 2 cents.
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3557568
my 2 cents.
From Webster Dictionary.
Main Entry: ca·nard
Pronunciation: \kə-ˈnärd also -ˈnär\
Function: noun
Etymology: French, literally, duck; in sense 1, from Middle French vendre des canards à moitié to cheat, literally, to half-sell ducks
Date: 1851
1 a: a false or unfounded report or story; especially : a fabricated report b: a groundless rumor or belief
2: an airplane with horizontal stabilizing and control surfaces in front of supporting surfaces; also : a small airfoil in front of the wing of an aircraft that increases the aircraft's stability
Take your pick. :P
Cheers GW :(
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3557611
The V8 supercars don't have them because the rules limit the amount of changes they can make from the factory profile of the car (I know, I know, don't shoot the messenger)
What they do have to compensate though, is a very extended lip on the lower leading edge of the front bar that is "supposed" to do the same thing (ie - increase stability on the front end) How much value is in this, when you consider that they don't run the massive tyres and obese amounts of front camber that the BMI and WTCC run, is anyones guess.
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3557778
supertaxis run 19x11s (or 12s, cant remember) all round... cant really say thats not large...
Ah, no......
They are only allowed to run a 17" rim maximum, with a 305 (10") control tyre.
Not a huge amount of rubber to put 650-700 horses to the ground through 2 tyres....
v8 supercars tech rules (for the non believers)
http://www.v8supercar.com.au/content/attac...ction_c_update/
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3558008
west
Yeah,
I was bored, watching BMI then i was just wondering if CANARDS really do works? Well all the super GT cars in Japan has them, so are some of the time attack monster overthere ..................so it has to work, even a bit right?
What if V8 supercars has them on? Why wouldn't they?
not trying to be a bastard but is english your first language? sorry for asking . . :blink:
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3558194
canards used to be fitted to v8 supercars in the early '90s... people might remember them on the seton and johnson falcons. the level of contact in that category might have seen them moved away from if the rules didn't.
they can work if designed and set up to work, i doubt most fitted to road cars have any measurable effect... all most would be good for is extra drag.
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3558214
Main Entry: ca·nard
Function: noun
Date: 1851
Take your pick. :D
Cheers GW :(
ha I'll stick with the duck one.
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3558489
Its for looks. I doubt you would notice it. High speeds?? 911 Turbo, Veyron, F1 Mclaren...I don't see canards on those.
Diffusers at the rear and flat underbody on the hand will do something for aerodynamics.
Canards are just one of those things that one workshop did (I think it was MCR?) and now everyone has to have it.
Back in the 70's people used to raise the bonnet up at the back maybe a couple of cms because someone thought it would be a good idea for heat extraction. It actually did the opposite because of the low pressure zone around the windscreen sucked air into the engine bay and kept the engine nicely insulated with its own heat. They finally realised and changed the design slightly e.g A9X Torana, rear facing sealed hood scoop = oldschool CAI.
/end rant
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3558708
ok so whats the diffrence with the ones on the time atack cars (canardon the frontbumber 1/2 way up)
and the one on JET 200 (off ignition dvd) that has them parallel with the front bumber on the bottom
no doubt both cars spent plenty of time in the wind tunnel testing alternative designs
https://www.sau.com.au/forums/topic/199648-canards/#findComment-3558856
    • Hey guys, Just thought it might be of interest to owners of the RB25 det NEO motor, that awesomeness Nitto are in the late process to produce an engine gasket kit by end of Jan 25.  I think obviously there will be an 25det kit too. cheers, Ian
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
