was under my car yesterday , and found this hanging from the top of my gearbox, not connected to anything. I assume it is part of the hicas tubing as mine has been removed from the car ,the two hoses were connected to the top of the gearbox
https://www.sau.com.au/forums/topic/199656-whats-this/
nah, wont hurt it, you may get a little bit of g/box oil come out there from time to time. with them longer and sitting up higher the oil cant get out. they usually finish up near the top of the gearbox bell housing.
https://www.sau.com.au/forums/topic/199656-whats-this/#findComment-3557826
yeah the 14mm bolt that goes through the bellhousing and motor, it is above the starter motor. easiest way to get at it is to lower the rear of the gearbox (loosen off the gearbox cross member), use 4x 1" extensions along the top of the gearbox right to the rear of it.
https://www.sau.com.au/forums/topic/199656-whats-this/#findComment-3558985
