Can someone give me a step by step on how to change my Power FC MAF thing to the z32 MAF? Thanks!
Hi, have you had a look/search in this here folder on page one matey? <Faq: Apexi Powerfc - Frequently Asked Questions.> Lotta good stuff in there by some very knowledgeable dudes, keep you amused for hours. :(
Cheers GW :P
Cheers GW :P
yeah I searched that before and I still can't find the answer.
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
Advanced Operation
43). # What do I need to do when changing my Airflow Meter
tells you what you need to know
when you select the VG30~80MM AFM and hit PREV that AFM is activated
    • yeah, there's a country that recently started importing Skylines, I blame them.
