JBL - mono amplifier 460 watts . cs300.1
PIONEER - 1000 watt subwoofer - Housed in a ported enclosure .
more or less 3 - 4 months old , still come with boxes . these items are in superb condition.item is located in sydney - PICKUP ONLY. please PM me for questions. i have payed over $500 for the lot , so i am going to be reasonable with the price and i am seeking $330 firm for the lot . cash sale prefered. thanks.
Edited by sky-017
https://www.sau.com.au/forums/topic/199673-fspioneer-sub-and-jbl-mono-amp/
