the quicker you can get it up on the transbrake the better just wire the gas to the transbrake button so you let go of them at the same time
not a bad idea
iv got some new pix on my camera to upload, my boot is finished, and im working on the engine bay a bit more. the harness is all hidden inside the drivers side guard, as are the relays from the std relay box in the engine bay. i wish i did that sooner, the ammount of room it opened up in there was amazing!
sweet build mate, yeh steve is awesome he helped me out a bit with my build ( although now im in qld) you'll be 9s for sure once everything is sorted and suspension set up is sweet.
ben...
ben...
thnx man. yeh steves a good bloke, iv never had a problem he cant solve lol. why you in qld now? werent you a gong boy?
<br /><br /><br />
haha thanx bud. just wait til its finished and at powercruise this year!! ( hopefully)
You might like this.BUSTERS 26/30 with T51r.Love the spool of the T51 on the trans brake.Sounds like its about to take off.
http://www.youtube.com/watch?v=dmqKrUxOJ4U
aahhh the sweet sweet sound of a big snail. hopefully mine with the sidepipe and 2k higher revs will sound as orgasmic at that LOL
Will you be revving it to 10600rpm?
Not a bad sound for a full exhaust and plumbed back screamer pipe :P
Nice set up 1TUF33 will be great to see her out racing
Is yours reving to 10600rpm?
Sorry i am about to go slightly off topic :thumbsup:
If so: what prep work have you done to the bottom end? Not talking basics like forgies, balancing, etc. Things like titanium rods?; internally harmonically balanced? (ie: rebalance the crank,rods, piston, etc assembly while assembled in the block); anything else?
Reason i ask:
I am in the process of building a rb25/30: Cams, valve springs, extensive professional head porting, 3 angle grind on valves, greddy plenum, q45 tb, ETM high mount manifold, cp forged piston, REV rods, ATI harmonic balancer, N1 oil pump, H.E. competition race sump, GTR race bearings, etc, etc............... (you start to get a clear picture)
Now with all these components (and obviously all the prep work) i was hoping to have a rev limiter set to 8000rpm. Considering a std rb25 revs to 7400rpm factory, i thought a well built, strong rb25/30 would have no problem with 8000rpm. But my mechanic is hesitant to set the rpm limiter there, due to the longer stroke of the 3ltr and claims that the block would have to be rebalanced internally, once assembled, which costs a few thousand extra (something i am not willing to pay). He explained his concerns about harmonic distortion/frequencies at rpm's above 7000 on a rb30.
Just wanted you opinion on the matter and whether you think my mechanic is being too cautious?
Of course you have to assume that my mechanic knows what he is doing and that the work is of high quality; i for one am obviously certain it is :thumbsup:.
Sorry Al I was only revving to 8600, 1TUF33 said "2k higher revs will sound as orgasmic at that LOL" and I was wondering if he was planning on revving to 10600
Your rev limit of 8000 sounds spot on to me
Thanks BU5TER :P
It obviously depends alot on the power graph too, as it may be useless to rev to 8000rpm. :thumbsup:
I left out the turbo on purpose, as i am using a "baby" turbo for this setup: GT30R
I plan to do alot of motorkahnas/hill-climbs and a few track days, so response has always been my main goal. Hoping for 290-330rwkw with the response better than that of an rb25 hi-flow turbo on a std rb25.
Not a bad sound for a full exhaust and plumbed back screamer pipe :(
yours does sound sweet mate, but i didnt think it was revving so hard! i think i was at powercruise when you ripped those powerskids, nice show
Sorry i am about to go slightly off topic :(
Reason i ask:
Of course you have to assume that my mechanic knows what he is doing and that the work is of high quality; i for one am obviously certain it is :/ .
as a matter of fact yes it is all internally balanced, from the stally to the balancer. i sent it all to a shop near me, and he returned the whole setup to me, labelled, in what order it has to be installed etc. im not exactly sure what was done, but i think he basically balanced it all together, not jusst the crank, so to get it all pretty close to spot on. the only thing stopping you from going past 8k i think would be the rb30 crank, from memory they are only semi counter?. my crank is a full counter job, so it may well be able to take the revs better. il ask my old man, maybe he could shed some light. hes a mechanical engineer, adn SHOULD have an idea on these things lol
are proper cages suposed to be press bent like those!?!?
its allowed to be press bent, as long as the distortion of the bend doesnt exceed a set limit over the radius of the bend. its all im the cams rulebook ( which is the same specs as andra use ive been told)
That sounds like what i have done and what any good engine builder will do. All components get sent to be balanced and matched to minimize harmonic vibrations, etc.
But there is another process that is very expensive and time consuming.
yeh it was really extra money i didnt have, but when spending that kind of $ on a motor you want to do it right
while i have this thread going, does anyone have one of those rubber grommets that sit in the injector seat on the inlet runner that seals the injector? i only need one, but if i have to get a set i dont mind!
Anyone????
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
