Hey Guys,
I've just finished installing some 740cc Nismo injectors in my r33. But the thing won't start.
Was thinking, either I stuffed something up, or the standard ECU won't run on larger injectors?
Any ideas?
I got a power FC ready to go in, just haven't plugged it in yet.
Thanks
Chris
https://www.sau.com.au/forums/topic/199712-nismo-740cc-injectors-stock-ecu/
Hey Guys,
Any ideas?
Thanks
Chris
The standard ECU will not work with the new injectors, only the Power FC with the right injector settings will run them.
Edited by nizmo_freek
Yeah your new injectors will be pushing way too much fuel in. There's a PowerFC FAQ up at;
http://paulr33.skylinesaustralia.com/docs/...powerfc-faq.htm
There should be enough info there to get you going.
Thanks guys,
I was starting to think maybe I dropped a bolt into the intake. :)
Now I just gotta find me a hand controller :D
Might want to do i bit of research before you put in injectors nearly double the output of the stock ones.
Use the power fc FAQ guide to roughly set the injectors,then get it tuned.Can i ask why would you put in 740s on a stock car?
I think your doing things a bit backwards.
  • 2 years later...
top link man
cheers
