Hi guys
I have been through almost every BOV topic / post / thread on this and the sylineowners.com forum ad infinitum, but still have not seen any discussion on the below:
Here's a little background info: I have an R33 GTST with...
2835Pro S set to 1.1 Bar
HKS induction
Z32 AFM
Apexi PFC / Boost control kit (and Datalogit on the way)
ARC Frount Mount
HKS SSQV BOV!!
Plus other bits that are not really relevant to this discussion
My tuner has plumbed the boost control kit into pre intercooler piping, basically just off the turbo (boost gauge on PFC commander never shows vacuum!), which I can understand the reasoning - you see actual boost pressure from the turbo, not post Intercooler / throttle body boost). Also, all recirc piping has been removed / blanked off, so I can't really head back down the recirc route.
Because of this new "plumb boost feed directly off turbo" method, I now see massive spikes of 1.9 Bar plus massive flutter on gear change (you wouldn't normally see this when the boost controller is tee'd off the manifold). I'm guessing here that the BOV is not opening enough (it does open a little though).
So, there are two things to note with this issue:
1. HKS SSQV. Now I don't want to go into recirc / atmo discussions (as we've all seen multiple different theories here :blink: ) so can anyone tell me if this BOV can discharge the excess boost (1.1 Bar) effeciently? One thing I've noted with this BOV as well, is that the pressure generated by the turbo pushes against the piston, keeping it closed. So in theory, wouldn't manifold vacuum have to be greater than the boost pressure to pull the piston out?
2. 1.9 Bar being measured at the turbo. Surely this is bad?! For the guys that do not run a BOV, when the throttle body is closed, this equates to (I assume that a closed throttle has an area of 25mm / 0.025m (radius) squared times pi = 0.001963m2):
Pressure = Force x Area
1.9 x .98 (to get atmospheres) = Force x 0.001963
1.82 / 0.001963 = 927 N
Force = Mass x Acceleration
927 = Mass x 9.8m/s/s (gravity)
Therefore Mass = approx 100Kg?!
So an instantaneous mass of 100Kg is either being applied to the throttle butterfly / throttle butterfly pin, or the turbo blades?!?! Even if my theory of obtaining a figure for mass is incorrect, there can be no argument that 927N of force is being applied to either / both these parts, instantaneously...
Has anyone else measured boost spikes on the turbo side, or is there something completely wrong with my setup?? Thoughts / input on my force theory would be welcomed, as would an idea on an appropriate atmo BOV to vent the right amount of boost...
Cheers
Steve
P.S. I have now changed into my flame-retardant suite - let the burring commence! :)
-20 points for doing math on NY eve :blink::)
Edit: I should prolly post something worthwhile.
Those BOV's have been used on cars running more boost then that.
The reversion and boost spike your seeing is clearly due to your BOV not opening properly. Check the vacuum feed your using (between TB and motor yes?) Check the BOV on the bench with a vacuum pump maybe?
The trick for easy 100% workability would be to use a recirc BOV, not an atmo one... but you don鈥檛 wanna hear that :D
Your calcs could be correct, but the way the comp wheel is shaped means pulses can go backwards through it much easier (iv heard) and air ain't that viscous
my 2 cents
Edited by GeeTR
You havnt taken into account that there is vacuum on the other side of the throttle plate, so that force is more like 150kg. I dont think a boost spike like that woiuld be particularly uncommon, its just that people dont usually measure it. Maybe try blocking the BOV altogether, and ill bet it goes to 3bar.
Kilograms are not a measure of force guys. All you've calculated is the mass you'd have to apply a force of 927N to in order to accelerate it at 9.8m/s/s in ideal conditions, which has nothing to do with this.
Stick with the 900N force, although in reality i think you'd find the conditions way, WAY more complex and delicate. Some sort of sensors would help :blink:
Stick with the 900N force, although in reality i think you'd find the conditions way, WAY more complex and delicate. Some sort of sensors would help :(
Hmmm, seeing as we are all living on the same planet, fro arguements sake Kg is an effective measurement, as he was simply trying to determine a relative amount in perspective.
-20 points for doing math on NY eve :devil::D
The trick for easy 100% workability would be to use a recirc BOV, not an atmo one... but you don't wanna hear that :(
my 2 cents
:worship: It was still afternoon here in the UK, so the brain was (kinda) functioning :) I'm not feeling particularly clever today however...
It appears the best route for me to take is get all the bits back for a recirc. Can this be done, even if my engine has been tuned for no recirc?
Oh, and happy new year everyone!
Steve
I don't see why you've set the plumbing up that way. With a decent intercooler you shouldn't be seeing massive pressure drops anyway.
As for the massive spike, a blow off valve is basically a piston or valve with a spring on it, and a vacuum/pressure line running to it. While the throttle body is open, the idea is that the pressure inside your inlet piping is equal to what's held inside the chamber in the blow off valve. What I'd make sure is that the vacuum line going to the blow-off valve is coming from somewhere post-throttle body.
i don't know how you came up with this, but it would have nothing to do with the air-flow dynamics inside the engine
The prob is the boost gauge and PFC boost gauge cannot be taken from the turbo compressor outlet, there is no vacuum in the turbo, and also there is massive pressure fluctuations. If you hook up a mechanical boost gauge, you'll see the needle dance around like crazy, and even worse when you back off, this is where your "spike" is coming from, doesnt mean the engine is acctually seeing 1.9 bar.
Boost gauge needs to be taken from manifold, and EBC needs to be taken from turbo outlet.
Thats what he is saying, the pressure spike inside the IC piping on gearchange is 1.9bar, hence the pressure on the closed throttle plate.
I'm not getting a pressure drop, it's the fact I'm getting spiking of .8 bar - that's the problem! I can only put this down to a faulty HKS BOV (I've disassembled for inspection, and everything's in order as far as I can see)
What I question with the HKS BOV is, if you have a look at the way the SSQV works, boost is always in the chamber of the BOV pushing the seat against the seal - it helps keep the valve shut (in theory you could block the vacuum line, and the piston will seal against the seat based on pre throttle body boost). Most BOV's (non-HKS!) I'm aware of use spring tension and boost found on the vacuum line to remain fully closed. When there is vacuum at the manifold, both manifold vacuum AND boost in the pre manifold piping are used to push the valve out / compress the spring, and vent the excess boost. What I don't understand with the HKS is, the vacuum release has to work against spring tension AND residual boost pressure to open! >_<
Well, to answer my own question (under "Product Detail") http://www.racinglab.com/mit3019turhk.html still not sure if I understand fully though...
Also (for Simon-R32), the way the PFC boost controller works is, it comes with a MAP sensor that plugs into the PFC and uses the existing two wires to the stock boost control solenoid. Because the PFC uses this MAP sensor to display boost on the Commander and control boost, the Commander will never display vacuum (due to my MAP sensor being plumbed into turbo piping rather than post throttle body). Is this OK? Does the PFC need to know if there is vacuum? Before I had the work done, tuned etc., I had plumbed the MAP sensor into post throttle body...
Thanks for all your input...
Steve
Edited by skybus
yeah your map sensor needs to be on manifold, then it will read vac and correct boost pressure.
im fairly certain your "spiking" issues doesnt exist either, its just air fluctuations from the turbo causing the gauge to go spastic.
i used to have an AVCR which uses the very same map sensor and solenoid as the PFC kit, and i had it hooked up to manifold and then to turbo outlet, and with stock turbo it said it was spiking to 1.5 bar... which is simply;y not true, the figures were fluctuating like crazy, i was only running 10 psi haha
I wouldnt be surprised at all idf the stock turbo without bov makes 1.5 bar on liftoff/gearchange. The turbo can be flowing 100's cubic feet per minute, at a pressure ratio of 1.7, then the throttle is shut, and the 100's CFM has nowhere to go, the piping/intercooler act like a big pneumatic spring, with the pressure building right up, then the pressure waves bounce back off the throttle body and out through the turbo, then the process repeats itself, hence fully sic flutter
Kilograms are a measure of mass, nothing to do with different planets.
I thought Kilograms were a measure of weight, and Newtons are a measure of mass. Its been a long time though.
I hate the SSQ BOV's; i found them to be more about noise than anything else. Have a look at the opening and you can see that its not significantly bigger than a stock item; thats why theyre so loud, so they cant really be efficient at venting air between the throttle and turbo at 1.9 bar. I really like the Tial 50mm BOV's.
Shaun.
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
