  • Replies 3.9k
Posted Images
my god
i may end up in hell one day... but it couldnt possibly be hotter than today was
and if you thought the new honda was horrible in pictures... it gets worse
Haha... Oh noes! Honda fcked it again........
Someone needs to tell Greg Rust to calm down...it was practice.
I seriously can't stand him, he takes his job way too seriously and just needs to relax (or even fire up abit like Crompto does) it's almost like he is commentating races from a script.
and not just the new guys having troubles keeping them straight
...as Pique jr can attest to. Hes not having the most stellar of outings to start the year is he? Just ahead of the S.A's.. not velly naiice.
I was working so unfortunately (or fortunately perhaps) didn't catch the full practice session on TV, but what I did see...my god, I've never heard someone so excited about a practice session...
i could swear, that on the move the back of the F2008 said jihad
how unfortunate... for team jihad
why not Jordan were sponsored for years by Bin Laden (may have been a different Bin Laden but who knows!!)
sorry they used to be sponsored by OSAMA
my bad
Edited by Whiplash
That's what I mean though, if they had TC would all these mistakes still have happened or would the TC have taken control. Normally their are a couple of drivers that have constant grass excursions but practically every single driver did on most laps of practice.
I'm thinking the second session, everyone was pushing to see where the limit was and go beyond that. First session to sorts of establish an average time.
Oh here we go...
Richard will be doing backflips after Kubica topped the sheets in praccy 3.
At least webbo is up there but wtf is going on at mclaren and ferrari? Kovi down in 19th, raikkonnen down in 14th????
wtf is going on with ferrari :P Kimi looked fast such a shame they had a problem :(
Good work by Kubica P2 The BMW look super quick, i don't think its only going to be a 2 horse race this season which is good to see :)
poor webber his curses continues :P
F1 is starting to look interesting again
Oh here we go...
yeah baby! go poland. he may well be the ugliest man to ever compete in F1 (not including niki lauda of course) but I told you fkers he was good!
there would have been a pole on the pole except for one massive massive off. were it not for that he would have surely had pole by a pretty decent margin. put ya cash on kubica boys.
and poor webber. no wonder he said "i'm pissed off" when interviewed. I would be too.
he's light, much like hammo i reckonz, so well done to Heikki
very entertaining session, webber crashed RIGHT infront of me, will try to post up pics on monday.
i think kimi's problems were more than fuel pump because as he passed me ealier that same lap the car did sound very unwell
bring on the 40+ temps
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
