.getting all pumped to see Webber up the pointy end again.
thats as long as Red Bull get to race
Red Bull will supply Malaysian race stewards with a detailed technical report after David Coulthard’s accident during Friday morning’s practice session at Sepang. Coulthard’s RB4 sustained what the team described as ‘substantial peripheral damage’ after the car suffered a track rod failure.
The team decided not to run the Scot in the afternoon session whilst they investigated the cause of the accident, and were subsequently requested to meet with race stewards to discuss the crash.
During the meeting, attended by Red Bull’s team principal Christian Horner and a technical representative, the squad were asked to provide a report "verifying that the integrity of the suspension is such that the car should not be deemed 'of dangerous constructions' under Article 2.3 of the 2008 Formula One Technical Regulations."
Stewards have the power to exclude Red Bull if they decide the car does not meet requirements, but the team hope that Coulthard will be back in action on Saturday morning for the final practice session ahead of qualifying for Malaysian Grand Prix.
  • Replies 3.9k
Posted Images
That's the ITV UK feed that is a free stream to UK residents only however someone has obviously set it up to stream via a proxy so that anyone can access it.
Be better if it was about 25% better quality/bitrate but yes it certainly beats waiting until 2am tonight to watch ch10's cutdown version.
Thats pretty bloody good news for Webbo then isnt it?! :rofl::D
actuall no it isnt,....He'll still manage to have someone harpoon the sidepod into turn one...probably a crazed Gonzo trying to do what the Renault obviously cant and that is win a race...
Be interesting to see how Louise goes in trafiic. He has been good to watch as he is almost wreckless the way he commits the car to the inside, outside...and sometimes dirt to get past cars. Surely sooner or later ppl are not going to stand for it and it will end badly. Always interesting to see ppl race from teh back, Kimi does it well. MS was great at it, Massa sux at it....so far Lewis has been all over the place but never got into the points from mid field or back of grid
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
