  • Replies 3.9k
Posted Images
at least it was a stand out on the grid, something new... which is rare
this is just ugly and unimaginative... and from the side it bears a striking similarity to BMW's colour scheme
yep..i find it hard to believe that Honda dont even appear to have a single other sponsors name on their car... very confusing considering that Toyota have stacks more money and yet they have a bunch of sponsors on their car.
these photos are funny...
Rubens looks a kid standing next to Santa in this shot... go on Reubs..wet yourself, its okay!
and Jenson...oh Jenson, much more than this.... you did it YOOOOOUUUUUUUURRRR WWWAAAAAAYYYYYYYYY!
Ahahaha, you wish.
Poor bastard.
I get grand stand tickets every year but never use them, so if anybody wants to upgrade and sit at turn one on Saturday for qualifying all day, let me know you can BORROW my ticket.
... You still need your ticket to get into the track but once you’re in you can have mine for the day
yeah... when the side pods, bridge wing, bargeboards side pod winglets and numerous other parts are 'borrowed' from last years Mclaren, they're obviously onto a winning idea
they do have a much better nose on it tho
Well if you removed the paint schemes from the cars other than the different height keels for the front suspension I reckon even the most ardent train spotters would struggle to figure out which car is which.
I like the fact that the three top teams (Mclaren, Ferrari and Renault), while always ultra competitive always seem very different in most aspects... be it suspension, side pods and especially front wings
I would say that the rest of the grid are indiscernible from one another is solely because they are a stolen mish-mash of the top three’s design concepts both aerodynamic and mechanical
Yeah... its too bad not all of us are 100 years old and were around in that era, hey?
:D
Oh very fkn funny. Fkn newbs.
Actually if you want a good read go buy yourself a copy of the book 1982. Get it from Amazon & it will be cheaper than locally.
http://www.amazon.com/1982-Inside-Story-Se...6608&sr=8-1
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
