hey i drive a '96 r33 s2 sky...bout a few weeks ago..i notice my door light on the dash does not go away..
and yes ive checked the door switch on the roof..and both switchs on the door frames..but no luck...
anyone had this problem before...
plus i heard that nissan sometimes the ecu will display lights on the dash wen thers a fault..etc..
any ideas would help..thanks
https://www.sau.com.au/forums/topic/199729-door-sensor-onengine-hardware-fault/
Ive just noticed the same problem on my car. I had a look around at all the fluids and noticed that my coolant was low. but i havent filled it yet. gotta buy some first thing tomorrow morning. then ill tell ya what happens. I have a 32 GTR so things could be different.
I had a stuff around with my car today and yeah cant find the problem. the hicas fluid was low but yeah the light is still on. so maybe its just a faulty door thing. I noticed when i turned the interior light on an off a couple times itd go off. but that stoped working. If ya find the problem let us know
Cheers
  • 3 weeks later...
Cheers
yeah, still cant find the problem either..
i plugged in the nissan computer to my car..
not error or faults wat so eva..
my tech mate reckons it somethin to do wit my alarm system..
  • 2 months later...
I've got a similar problem with my car. Red 'door open' light and the interior light flashes on and off, happens more over bumps, or under hard acceleration. I'm assuming ive got a loose wire in the boot, which runs from the boot to my alarm. i've seen my red door light dim and fade, so its not like a switch flicking on and off - but more like a bare wire earthing somewhere.
Good luck finding your fault, have you tried pulling apart both door switches? Also check if you've got a bonnet-pin switch (possibly fitted by alarm installer). Finally check boot switch which is inside the lock mechanism, in the boot lid.
Edited by Trav33
so r33's have a boot switch in the actual lock itself????
...k i give it a look..
coz i did notice that my boot light stays on!!!
i can c the light beam onto my rear window at night...
so i had to remove the little wedge globe..
and ive had it out ever since, plus my interior light is always set to off..otherwise the light will remain on forever..lol
and ive had this problem for a while..
maybe my sub going off knock a wire lose or sumthin...
i checked the bonnet alarm switch, seems fine, and i gave it a clean wit electrical contact cleaner..
and i checked both door switch pressed them in and out, took them off etc..
no good, door light remained on, and interior light will still remain on aswel...
but i tried finding the switch for the boot but no luck..and no one knew either...
but yeah..thanks
but i'll take a look =)
does the boot lock have a wire coming out of it or anythin?
and its on the boot lid on the actual lock on the rear panel???
more information on this would b great..
thnks
From what i understand, if you open your boot, the boot-switch will be in the lock mechanism on the boot lid (not on the car chassis itself) You'll notice a black rubber tube on the right - the electric wire runs through there. This is what i've been told, havent had time to pull mine apart yet.
i would check the two door switches first, as they are whats connected to the light on the ceiling. if the ceiling light is flashing on, its because the switch is opening on one of the doors and you have it set to "door".
set the interior light on "door" and have a play with the rubber buttons to see if they are working or not
alarms usually have their own boot/bonnet switches that are in no way connected to the doors.
Hrmm every car i've had, the alarm has always used the same boot switch. The alarm taps onto the common 'door' circuit, so that when the circuit goes to ground, it triggers the alarm.
Bumble_Bee - have you tested your alarm to make sure its working? Try arming your car with the windows down, then unlock the door an open it to see if the alarm sounds. I wouldnt be surprised if your alarm isnt working at the moment which could be of concern!
Edited by Trav33
umm..ill check it out but im pretty sure its working..
um.. i did found two wires under the boot lid carpet..which go to the lock..
and the black rubber tip on the end is kind of worn... :|
is it spoz. to have any metal exposing on the tip of the boot lid lock?
because it looks like on mine that the black rubber tip/cover has worn off...
but can anyone tell me wat these two wires to do?
Edited by bumble_bee
This is what mine looks like. You can push a screw driver in to simulate the boot closing, and should see your boot light turn off.
Does yours look the same as mine? There is a black plug half way up the boot, if you think the lock is dodgy, disconnect the plug.
yeah, mine looks the same..
but y wedge a screwdriver into the lock? lol
i dont think the lock is earthin correctly on mine...
so mayb if i could figure out how and y?
i could fix it..
mayb i should try earthin one of the wires...
but i unpluged the harness but nothin..
problem still there...
wat do u think the earthin point is on the lock?
yea..i was thinking that but me and my mates still recon it that in my boot lid...
wen u unplugged ur harness does ur interior light/door light turn off??
When i put my screwdriver in the latch, the light turns off.
I imagine if you unplug the harness, the light should turn off too.
However if you have something on the 'door circuit' which is grounding, even if you unplug the boot switch harness your lights may stay on, becuase the problem is somewhere else, not there.
  • 1 month later...
k, defiantly found the problem...
THE PROBLEM!!!!!!
the guys who fitted my alarm did some re-wiring coz of the features of alarms these days..etc..
well on the driver door switch..theres 3 wires...anyway i never took the panel behind it off before..
anyway..i had a look and found that they soldered two extra wires which go the back of the car..dont no wer too?
possible the rear ilt/shock sensors???
and way i tampered wit it and taped it up better..and now it seem's all good..for now..lol
so it was the extra new wires connected to the drivers door switch...
i have no idea wat that switch in the boot lid does..lol
HOW I NOTICED THE PROBLEM!!!!!!!!!!!
and i only really spent time on it today..coz of last nit..
my alarm went off like 4 or more random times...by itself..there was heavy rain and strong winds..but who knows..anyway then..
today at work i saw my car..just go off...for no apparent reason..lol
wen it wasn't raining or any type of wind...
and dis-arm itself and did it like 4 times in a row..and all random times...etc..
and so to stop it i hand dis-arm my alarm..and my car was unlocked for the whole day..
anyway i got into my unlocked car after work and realized for the first time in like 4months when my key was in the ignition..that the door light WASN'T on..lol
then i drove for like 10mins on my way home and noticed the light had re-appeared!!!!!!! :)
anyway..i opened my door at the lights and re-closed heavily with anger..lol
then i notice it disappeared again..wat the???
then again like 5mins after..like going around a round-about...
i saw it re-appear once again...
closed my door heavily once again..and it was gone..
so i def. knew it was my drivers door switch/ or the wiring!!!!!!!!!!!!!!!!!!!!!
and it was all that time..the wiring was loose...lol
and getting knocked around in the "b pillar" panel and the interior trim...
so that wat was setting my alarm off and on..the wiring earthing or re-connecting a live circuit...
and hence my alarm thinking someone opened the damn door!!!!!!!!...lol
i tht i was in need a of a new battery..but my battery was pretty new..so yeah
this all came to me today...
PROBLEM SOLVED!!!!!!!!
So if anyone get or has a similar problem like i have had....
i hope this helps!!!
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
