i think i got a little to close to the fireworks, in my area they were shooting them at each other lol. they put a few upside down on purpose i think :s and i have to say it looked pretty cool/dangerous watching them blow on the road, i had to dodge a few as they came flying down the road. almost went deaf when someone decided not to tell anyone they were going to let of a loud ass bunger... was a good night all up.
ps. HAPPY NEW YEAR
Edited by phat_man
https://www.sau.com.au/forums/topic/199738-nye-08/#findComment-3558512
oh im cut, i didnt see the fireworks i was on a train :worship:
ended up at the eastern hotel at bondi junction wasnt to bad.
hope everyone had a great new years
hahahahahahahahahahahaah
Used to work there lol
I ended up walking 20km's from my house to the firworks and back..
https://www.sau.com.au/forums/topic/199738-nye-08/#findComment-3559086
I waved a sparkler around in the backyard with my friends and cousins. We left our run too late and could only get one sparkler each due to a lack of boxes of sparklers at all the shops we visited.*
* This may or may not be a fabrication of the truth...
HAPPY NEW YEAR'S, everyone! :worship:
https://www.sau.com.au/forums/topic/199738-nye-08/#findComment-3559264
I was on a mates 45ft Catamaran next to Man'O'War steps (next to the Opera house), so I could've waved at you Shauny.. :)
got sooooo drunk :S
had fun laughing at all the plebs in the crowd around Circular Quay and looking at everything through a Thermal Imaging camera... some people have REALLY hot crotches... we also tried to see if we could fry a christmas ham with the Radar... no go, unfortunately.
Also, managed to do a double front tuck off the roof of the Cat (about 4.5m above sea level) into the sea.. too drunk to care about pollution/safety etc.. lol
One of the best NYE's EVER!!!
oh, and the view was ok too :P
https://www.sau.com.au/forums/topic/199738-nye-08/#findComment-3560290
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
