Just installed a couple of gauges to keep tabs on things, ive been using the factory gauges so far but we all know the oil press gauges are quite dicky sometimes!
Anyway, once up to operating temp, oil press is at 3-4 bar at 1000 rpm, and at 3000 til redline goes up to 7-8bar.. seems a little high?
oil temp also seems to take a while to come up... and sits at 60 degrees just sitting there idling and its 40 degrees outside... i havent driven it yet so im thinking its prob not loaded up enough. theres an oil cooler on it with an oil thermostat.
Edited by Simon-R32
Hi there, I cannot comment on your oil circuit (me unskilled) except to ask how did it used to work(?) but as far as the measure checks go & without immersing electrical bits; Oil temp can be checked by pulling temp sensor & placing sensor tip in mixture of ice cubes/water gently stirring while still connected & elect/power on. Should read 0 deg. C or thereabouts. (You will need to run a temporary neg wire from body of sensor to bat neg for each sensor test if sensor single wire type.)
Next place sensor tip in boiling water, don't burn pinkies allow to stabilise/warm up (1-2 minutes max) should read 100 deg C.
Next, find someone with portable test pump & standard pressure gauge 0-10bar (like me-instrument basher) & pump the pressure sensor gently (doan wanna pump the guts out of it) up through the measuring range. Compare against test gauge. If allus good I would be happy to have your oil system in my car.
Cheers GW :(
PS: I live beyond the Black Stump so cannot drop in to help.
Edited by 260tech
Those readings do seem a little high.
From memory the manual says it should be ~1bar at idle and i think 3-4 bar for anything over 3k rpm
Maybe the fittings on your oil cooler are a bit restrictive, hence the higher pressures
its 80psi @ pressure relief setting in the factory manual.
so if your at 100, a little over, but wouldn't be concerned to much myself.
either the pump might be shimmed up, pump off another rb engine or maybe oil viscosity plays a part.
not only what weight of oil but brand at cold start visc. especially....
Generally you cold start CST rating will be quite high for a 50/60wt oil e.g a 15w60 when compared to OEM specs. Nissan oil which is 7.5W30 from memory which will have a much better cold start visc. rating and your pressure should start a bit lower and get to temp faster.
Once at temp I would be intrested to see what the pressure is. Mine jumps up to 3-4bar initially until it gets to temp then operates as expected eg 3bar 3k and over.
my 2 cents.
Regarding the oil temp, where in the circuit is your temp sensor mounted? out going or return? and if it's on the return side will it see any oil before the thermostat opens? I'd expect it doesn't open before about 80 degrees.
With my N1 pump I see 100psi on cold start, once at normal operating temperature I get 12-15psi at idle (sometimes only 20psi if it's a really cold day), pressure climbs quite rapidly with revs, 40psi at just over 2000rpm, 60psi about 3000rpm and up to 80psi by redline.
P.S. After seeing the problems with a couple of different B&M shifters that mates have had recently, I wouldn't trust B&M as far as I could throw one of their dodgy mexican workers!
Edited by bubba
You could bypass the cooler and put the oil filter back onto the block and see what the pressure is?
At least then you know if its the cooler or something else
was out on the track on sunday... oil temp seems to be low!! pressure was fine once it warmed right up, with around 1.5 bar at idle and up to 6-7 bar at full noise, shoots up quick from idle to 3000 rpm, so all is good there.
temps however, the hottest i could get it to was 85 degrees, that was after several hard 3rd and 4th gear WOT near limiter drift.... so yeah, i was expecting it to reach at least 100 and stay there, track temps was around 29-30 degrees too so not a cold day.
thoughts?
i would expect 80-90, closer to 90 fixed value but under all conditions, not dropping below 80 thats for sure.
it will depend i think partly on the thermostat setting, if its got a low degC rating it could be opening to early and wiping off the heat all the time and keeping it lower then you want.
i know there is guys that race here and could tell you for sure how it works, but if your stuck head over to performanceforums and ask "hsvsux" what the typical behaviour is. he track races his rb and has oil coolers, fairly sure with a thermostat system, but have to ask.
if its too cold you will not get maximum protection from the oil.
edit: i remember on a bmi video, they raced 3 gtrs, r34 v spec, r33 v spec, r32 non v spec, because the r32 didn't have an oil cooler as standard like the others, the driver cooked the oil after a few laps, racing the other gtrs and had to basically slow down and stop, oil was 130+degC off the guage, haha
Edited by RB30-POWER
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
