I want to upgrade either the intercooler or the management but i am not sure which one. Can anyone help with pros and cons of each one. I have a Blitz 3inch stainless steel system from the turbo back with hi flow cat and muffler and an Apexi pod filter, Gab coil over suspenion. Maybe there is something else that should be done before please let me know any feedback will be valued
Cheers Jon:burnout:
https://www.sau.com.au/forums/topic/19974-intercooler-v-management/
After seeing gus's car @ the sst dyno day I'd be inclined to say do the ecu first. He's making over 260hp with exhaust, bleed valve and a powerfc and is still using the stock intercooler, and I dont think he's having any drama's with detonation. If you want to put a bigger turbo on or use the car for track work or want to fang its tits off in 30+ degree heat I'd consider the intercooler at some stage.
Grey skys, yeah, go for the management. Decide how far you want to take engine mods and find a s-afc for the short term or a pfc for the long term.
drifta, don't you also have a mega-dollar exhaust manifold? That would make some difference too.
Nexus_SiX, I like your intro www page. Almost got me, then I started wondering why I was seeing an IE error while using Opera under Linux :D.
A Wolf plug and play is $2000 drive away with boost control and
PC sortware and lead, fully tuned. It can run any injectors you want and can use the airflow meter or the in built MAP sensor and has air temp compensation and many Aux outputs+ inputs,
Power FC have no Aux outputs and boost control is a high cost
extra and is stuck with an airflow meter and a handcontroller.
Steve - judging from the results in Gus's car vs Paul's car, which is in front in your opinion?
Top end power vs $$ spent it seems the Apexi one is the better of the two - just wondering if you wanted to add your thoughts..
John, why don't you put it on the dyno before you decide? I am just about to install my S-AFC, then I will get it dyno tuned. I will give yoiu before and after results. I still have the stock intercooler, we have similar mods on our cars, so results should be similar.
Personally I don't think it is worth spending a lot of money on ecu chips ( is that what they are?).
angel...
on my R33 with cat back HKS, stock turbo and stock cooler... running 12psi
Before SAFC - 181rwhp
After SAFC - 221rwhp
** and after leaving the workshop fried my clutch with 5 minutes.
Danel
Id also be very interested to hear opinions on this..
I went through the whole Power FC vs Wolf 3D V4 thing a little while back. As some of you know, I ended up getting the Wolf through SST and to this point, extremely happy with it. I have 260rwhp at 15psi using stock turbo and injectors on a SR20DET (S14).
Why did I go for the Wolf?
1. Laptop tunable - there is so much more resolution and it is heaps easier than using a hand controller
2. Built in boost control - no need for aftermarket EBC
3. Can use MAP or MAF - with the Power FC you can only use MAF (unless you get the D-Jetro, which is JDM market only, thus no warranty in Oz). Sure you can buy a Z32 MAF, but that adds another $300+ to the price of your modifications
4. Logging - the Wolf has simple logging on the handcontroller, advanced PC based logging coming soon.
5. Price - at near $2k installed and tuned, can you really go wrong? And this is with local support and warranty.
6. Multiple maps - using either a laptop or the memory modules, you can switch between maps on the fly.
There is heaps more, and I love it :-)
Originally posted by Strich9ine
There's some nice little gains from an AFC!
I'm hoping for around 260ish HP at 12psi from my AFC2..
p.s. I got 208 at 7psi with retarded timing and lotsa misfiring....
You've got much the same mods as me Strich... methinks you'll be looking round 250 which you'll find is a nice improvement on 208! :D
If you don't have an auto go the light flywheel. Drop your 1/4 times by 0.4sec.
Management over the intercooler. Even the humble S-AFC II will work wonders and leave some coin for other mods.
All up I reckon for $2k you can :
Ogura flywheel / S-AFC II / HKS exhaust cam gear / KCA349 rear cradle kit / Maybe get a custom front underdrive pulley machined up and some exhaust wrap.
Thanks for all of the replies guys, think i might go for the management side of things the wolf system sounds the shot. How much power do you think i will make after the computer with the mods that i have? Will i need a boost controller with the wolf 3D or are there different settings on the computer, if so how easy are they to alter, will i be able to do it myself or will it have to go back to SST. Steve how much will it cost to get a power run done. I stopped in Myaree duno tune and it was going to cost me $125 which sounded a bit rich.
cheers jon
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
