Some small facts first off - r33 gtst s2 (1996) with no mods apart from apexi pod.
I recorded a video using my mobile phone so the quality isnt the greatest. Ill try to provide an explaination to help.
http://www.youtube.com/watch?v=02Cyv2CWqDU
In the video you can see that my idle is fluctuating from about 100-1000rpm. This occurs when ive been driving the car for around 5-10 minutes, or generally once its all warmed up properly. You may also notice that as the rpm fluctuates, so does the vac/boost.
About 3/4 through the video you can see me open the throttle a little bit. The following is what i deal with on the roads when driving. Say im in second and approaching a corner or roundabout and have to give way so i slow down. Its very likely that the car will completely drop off all rpm and die on me. In the video im in neutral or first with the clutch in i forget. Either way, when im in first and i start to slow down a bit after opening the thottle, its very likely that the rpm will drop off to around 0 but not actually stall completely. As seen in the video i rev it a bit, then the rpm drops to about 0 and the battery light flashes for a second but the car doesnt actually die.
Anyway, i plan to take the car to a workshop/garage this month to solve this issue however if i can do this at home id be excstatic.
After searching the forums heavily ive come to the conclusion that it may be caused by one of, or a combination of the following:
-faulty afm
-leaking i/c piping
-dirty aac valve
-faulty o2 sensor
-faulty tps
Ive read that cleaning the aac valve can do wonders; is this the type of problem i can solve by cleaning the aac valve at home? It's just that i dont have a large amount of cash to wave around so being able to fix this my self would be great.
https://www.sau.com.au/forums/topic/199778-is-this-idle-hunting-bad-idle/
if not a factory computer, this can be caused by having the first few cells of the map unbalanced, ie on powerfc first 3x3 should be the sameish in fuel and timing, otherwise you get this sort of thing as it jumps through bouncing off different values.
if standard ecu, check your afm wiring and plug, and if all good try cleaning or getting a replacement aac valve
mine did this when rolling up to a set of traffic lights in neutral
it was the AAC valve. You can check this by temporarily disconnecting it. if ya idle doesnt fluctuate after disconnecting it, well theres ya problem
i ended up putting on a sr20 aac valve that was apperantly the same and doesnt do it anymore.
I had the exact same symptoms as you after pulling everything apart for a turbo upgrade (pulsing idle when stationary with car warmed up). In my case it turned out to be an air leak. Check all vacuum hoses connected to the crossover pipe and intake manifold for broken/split ends. Also check your Intercooler piping and make sure there are no leaks after the AFM. Definitely clean your AAC Valve regardless as many have mentioned.
Gave the AFM a good clean today, the inside was full of black shit. Gave it a clean with some electrical contact cleaner and put it back, the car seemed to run better than before. It still has a rough idle at times but its not as frequent.
Tomorrow i'll be cleaning the aac valve, hopefuly that helps.
I have the same thing. At first I thought it was a Vacuum leak, but after testing with soapy water and listening with a hose I found nothing. Now I suspect it is a faulty O2 Sensor. When the car starts idle hunting try disconnecting your O2 Sensor and wait around 30seconds. When I did this my idle stopped still at 900rpm.
My theory is that the car runs fine until the O2 Sensor is warmed to operating temperature as the ECU ignores this reading until that time. Once the O2 sensor is operating, the ECU reads a false value and idle struggles as the O2 Sensor is not able to keep the ECU up to date with accurate readings. I tested my O2 Sensor at operating temp with a multimeter and noticed that it does not vary in voltage as it should. I am going to test another O2 Sensor. Will let you know how it goes.
Very interesting theory. Last week i gave my aac valve a very good clean. At first it seemed like the problem disappeared but after about 30min of driving it happened but only to a small extent. No where near as bad as it was before. The aac valve cleaning definately helped.
Unfortunately, i havent been able to drive my car enough to see if the problem has gotten any better. I got busted driving it last week and got 2 fines, one for it being manual and the other for high powered vehicle (im a p-plater). Its my second car and i drive it like once a week but i dont feel like risking more fines. Im fully licensed next month though.
The o2 sensor stuff sounds like its worth a try if it happens to me again, ill keep it in mind.
thats how my car was running when i took the BOV off and turned it on LOL
so definately check for leaks in all piping such as vacuum and intercooler/intake side of things
but as others have mentioned before try someone afm
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
