I have a 1991 GTS-t, and the small spot welds my clutch pedal bracket snapped. So I bought a Nismo one, but after I took the old one out, removed the pedal from it and moved it over to the new one I have a problem. I can't figure out how to mount the assist spring back to the pedal. Is there some kind of trick to doing this? I have spent like 2 hours with this unit in front of me and I can't figure out how to get the damn spring back on the new, or even the old bracket so it works right. Has anyone done this before, or does anyone have a pic of a R32 clutch pedal bracket that they can post up so I can see how is it mounted?
Thanks.
Why didn't you just weld the old one back on?
It's all I did.
I did, three times..lol The welds just kept breaking, it also doesn't help that the bracket is made of tin can thickness metal and that I have a clutch so stiff it seems like I have gone to the gym everytime I drive my car.
After the 3rd time welding it I told myself if it breaks again im just gonna bite the bullet and get the NISMO one.
  • 2 months later...
Hey dude its easier then it sounds, same thing happened to me.. u know how i did it.. i got 2 zip ties.. squeezed the spring until it was compacted with multigrips and then put the zip ties on one on each side, put the 2 ends in place and then cut the zip ties.. worked for me.
If you like i can take a pic of my spring so u kno how it looks when ur putting it back in?
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
