Rb26 Geting There Lol
blitzxtr
 Share
Specs of Engine build
Mahle Pistons
Greddy oil pump
eagle rods
R33 Crank Grubbed screwed
Tomei buckets & springs
Nitto Vavles
Tomei Cams 280 by 10.5mm Lift
Ported head
N1 Block
Trust Manifold
Hypertune plenum
700cc injectors Maybe going bigger if needed
280 with 10.5 lift!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
damn man.
post up a video of this thing at idle and on the track.
that is pretty aggressive.
IM IMPRESSED.
must have taken ages and a fair bit of dosh to pull off.
congrats
Well yep for a while till i can affort a buz box to get me from work to home. Not cheap rebuilding a strong GTR
I said that to myself many years ago when i got my gtr. also dog box, and fairly decent power.
i've only just now gone out and got myself a daily driver. tho for about 9 months i also had a old 4wd
get the little buz box now! trust me!!
tho there aint nothing like a dog box!
Ah great looks like im going to have fun driving it home from sydney to newy lol.
looks niiiiice!
if all goes well, should be much fun :)
what size exhaust housing u got on the to4z?
Shes A .81 rear housing maybe go to 1.00 later down the the track or fu** it go a HKS SPL T51R
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
