Rb26 Geting There Lol
blitzxtr
 Share
Specs of Engine build
Mahle Pistons
Greddy oil pump
eagle rods
R33 Crank Grubbed screwed
Tomei buckets & springs
Nitto Vavles
Tomei Cams 280 by 10.5mm Lift
Ported head
N1 Block
Trust Manifold
Hypertune plenum
700cc injectors Maybe going bigger if needed
280 with 10.5 lift!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
damn man.
post up a video of this thing at idle and on the track.
that is pretty aggressive.
IM IMPRESSED.
must have taken ages and a fair bit of dosh to pull off.
congrats
Well yep for a while till i can affort a buz box to get me from work to home. Not cheap rebuilding a strong GTR
I said that to myself many years ago when i got my gtr. also dog box, and fairly decent power.
i've only just now gone out and got myself a daily driver. tho for about 9 months i also had a old 4wd
get the little buz box now! trust me!!
tho there aint nothing like a dog box!
Ah great looks like im going to have fun driving it home from sydney to newy lol.
looks niiiiice!
if all goes well, should be much fun :)
what size exhaust housing u got on the to4z?
Shes A .81 rear housing maybe go to 1.00 later down the the track or fu** it go a HKS SPL T51R
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
