Hi all
I was pulling apart my r32 ignition the other day and noticed something weird, one of the coilpacks is different (see pic)
5 of the coilpacks look like the one on the left, with the solid connector, but one has just a wire coil (right). (obviously I've removed the rubber boots for the pic).
It was suggested to me that the one with just the wire coil may not give as strong a spark. It has a different number stamped on it also. Might be nothing but just want to eliminate it as a possible cause of low power.
Anyway, I was just wondering if someone had a stock r32 GTR coilpack, with a solid tip, like the one on the left, to sell.
Cheers
Andrew
https://www.sau.com.au/forums/topic/199844-wanted-1-x-r32-rb26dett-coil-pack/
Don't stress, Both types will work fine. The one with just the springy wire sticking out, i also have on my 94 GTR and the one with the carbon conection i had on my 90 model spare GTR engines. some coils come with springs, some come with carbon connectors. I have used both and had no problems with at all with either. i do have spares for both if you are that worried.
Hope this helps
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
