Hi All,
I just got about 10 seagull turds on my car at work, washed it off within 2 hours but the damage was already done. I used a pressure washer to clean all the crap off but the 'residue' left over is stuck on the paint! Colour is a dark blue and had a full respray about 1 month ago.. :)
What's the best way to remove the residue/stains? Any help appreciated
Cheers,
https://www.sau.com.au/forums/topic/199860-bird-sht/
With WD-40, the paint won't sqeak as it moves around!! <<WTF?
LOL... i accidently got some silicon on my car last week and i didn't know what to use to get it off and all i had was some petrol and a can of wd40..used the wd40 and worked a treat!!
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3559742
bah try hot water mix with some terps but do it quick or else eat the paint i think and have hose with ya as well when ya do it lol should take it off quick if not wipe it down as well , a car detailing friend told me to do that but not reccomended to do i never tried it my self maybe for you should try it ,
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3562933
The 'residue' doesn't come off with a pressure washer or sponge & detergent but it feels like it is sitting on the paint, not eating through.. i thought bug & tar remover was very harsh on the paint??
claybar
will remove anything sitting on the paint
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3568202
So WD-40 is like a cure all? Like Windex in My Big Fat Greek Wedding? Spilt silicon, get WD-40, have a cold, get WD-40, get hit by a car, get WD-40. Its a mirricle formular!!
And thats the end of my randomness for today!
seriously try windex as i find it work really well to get bird crap off the paint
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3568208
Claybar is good but I just didnt wanna throw the idea around to someone who has never used it. If it scratches the paint I dont want to be reponsible for fixing it!
Bug & Tar remover isnt harsh on the paint. A good polish after ad you'll be sweet...
https://www.sau.com.au/forums/topic/199860-bird-sht/#findComment-3571299
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
    • Which grit sand paper did you use on the pulley btw? Thought I'd ask so I don't scratch it up too much
