Can anyone help ???
I got a r33 gtst and the oil pressure never goes under the second line (before the 4) but my friends RB25DE r33 goes all the way down to close to 0 when its idle.
The car makes a weird sound when its at idle (she calls it the gremlens) but its like a howling sound. Could that mean the oil pump is stuffed?
as soon as you raise the revs by at least 300rpm the sound goes away and oil pressure goes back to normal levels. (just before the 4 or abouts)
When driving its fine......
Whats up with the beast ? does it really matter to have close to 0 oil pressure on idle ?? The engine is NON turbo...
When I put 5w-50 fully synthetic oil in my car I had the same problem. I then put some 10w-50 in and the problem went away. My conclusion was that the oil was way to thin for the engine.
This may have something to do with the problem your friend is experiencing.
I thought it was 7.5W-30 factory recommended. I'm using 5W-30 and don't have any oil pressure problems. I actually slightly over-filled it and I was waiting for some of it to burn off but it's not happening.
Guest RedLineGTR
As far as i know on a proper idle from factory specs when the car is at optimal operating temps it meant to sit on number 1, 1.5...
I been using 5-40w oils the pressure is exactly the same as in facotry specs, i tried a more expensive oil 10w-60w abit high but oh well though i tried it, the oil pressure was sitting at like 3-4 nearly double, it was too thick, very high tech engines and the oil aslo dosent get around everywhere it supposed to be. Probably wouldnt go over 10-50w maybe 10-40w would be perfect.
the stock gauges / senders read low, regardless of what oil you use (i have tried many viscosities) when warm. I have an aftermarket Trust oil press gauge and when i'm revving it the stock gauge reads just over 4, but the trust one is at about 6-7. Don't worry too much, @ idle the stock reads about 1, the Trust one at 1.5. :D
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
