hey mate,
what led's did u use for dash lights... i brought sum of the proper blue t10's (think thats what they are called) from 666DAN on here but only worked for a week or so and now none of my dash gauges light up (only warning lights and indicators do so).....
thinking it may be faulty dash clucter tho
bought them on ebay @ 20 bucks, they are the ones with about 5 little LEDs on the t10. 2 of them just stuffed up the other day and im looking into making some new ones myself which can handle the voltage, i'll let u know how I go.
Nice dash lights but not a big fan on the glitter interior. Just a suggestion, if you have the spare cash perhaps a new steering wheel. Im looking into getting one probably momo but not sure which model as yet, any suggestions ppl?
In re to 666Dan leds, originally he was supplying Leds that handle only 12volts of current but after a few complaints from ppl stating their lights would randomly flash & then eventually die in the ass he investigated the matter and discovered the dash voltage level in the skylines would randomly fluctuate. He now supplies 16volts leds which i have recently installed & so far so good but it's only been a week, so finger's crossed. Blue leds rock!
Nice work mate! Unique. I have the blue 5LED globes and none of mine work atm....they come on randomly but I havent had a full cluster in ages! Cobalt gauge selection tops it off. I wouldnt go changing steering wheel, I like the stock one, besides, jus as an example, here in Mildura I hear of people being done for not having an impact material on their wheels and replacing the airbag is a big no-no. Ur call tho. Do I see AVS rims under your car??
Once again, great to see individual tastes and ideas, even if they arnt everyones cup of tea!
Yeah, thanx mate. U can't c in the photos but at night under the proper light u can see my purple pearl through the clear which i put on top of the glitter spray ( the photos were done via my phone so they don't look right). Anyway I got the autometer cobalt series because they were the only gauge that matched the stock cluster and i wanted the needle in the gauge to be lit, but little did i know that they lit up blue at night, so i had to change my cluster lights cuz i hate it when they don't blend in. PS. those are AVS shoes u c, but will be white 19" Enkei soon i hope..
Well, it's RICE... however, I have to say, you tastefully 'riced' up your car. LEDS are nice and make the car look clean and sporty in my opinion whereas the consoles and glitter etc are your opinion so don't let anyone tell you what you should or should not do - -personal taste.
Overall, nice... I'll PM you as I need new dash LEDS and might need your help - I'm from Melbourne too.
Looks good Steve,
How did you take the drivers door control panel off? I've resprayed my dash a matt black, and now need to do the door handle bit.
 Hi, thanx. U need to look in the coin hole and u'l see a little black cap at the bottom, take the cap off with a small flathead screwdriver (from the right hand side) and u'l see a screw under that. Unscrew that and then you can yank it off, don't be afraid to use a little force because its clipped in aswell. Same goes for the passenger side.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
