Hello,
I know a little bit about skylines, ive owned one for a few years but one thing i dont know and havent been able to check for awhile is about the dump pipe.
I was thinking about buying one of those dump + front pipe in one which is one pipe 3" mandrel bent but i wont to know is that all i need for the standard turbo? or do i need a split dump pipe for the wastegate aswell?
https://www.sau.com.au/forums/topic/199971-quick-question/
For standard upgrade applications the bell mouth version is fine. You will not notice a difference between split and bell. But the price JJR have on those splits is pretty low, so its not a bad buy at all. The only problem you may have is like a friend of mine who bought one of the ones pictured and he had to grind back the separating flap to make it fit, apart from that it was fine though.
https://www.sau.com.au/forums/topic/199971-quick-question/#findComment-3561211
whats that pipe? How do you call that? and how much is that? It looks good!
thats a dump/front pipe, goes from your turbo to your cat. My bro bought one for $280, not bad at all. Looks good and i like it better than the old small split dump (which is like 15cm long) then you have to get a seperate front pipe.
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/199971-quick-question/#findComment-3562431
we noticed a difference changing from a bell mouth to a split dump on my gf'ds stagea...
https://www.sau.com.au/forums/topic/199971-quick-question/#findComment-3562473
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
