hi guys went to start the 32 yesterday and all that it was doing is the starter solioind was clicking thats bout it i checked the batt and even used a next door neighbours ford battery to try and jump but same problem im going out now to give the starter a bit of a bash and check the fuses but i dont think that will
help i think its an electrical problem cause when you turn it to start all the warning lights flicker and the hicas makes a weird gurgling noise as opposed to the usual fuel pump soud it has any help would be greatly appreciated
cheers josh
https://www.sau.com.au/forums/topic/199975-gtr-wont-start/
another thing is check that the battery terminals are secure and tight. sometimes they make enough contact for a while then the wriggle a little the last time u drove it and now dont have the contact to draw the needed power from the battery
https://www.sau.com.au/forums/topic/199975-gtr-wont-start/#findComment-3560966
yeah it has fuel it dosent crank over it is only the starter solionid clicking and battery terminals are secure but i need to do get a battery charger or a new battery i left the door a little bit open last night after working on it and its dead,and i checked all fuses this morn as well and there fine i think it has something to do with the thermos i wired up but i took the positive wire off the battery and only left the earth connected to the relay and it still did it so then i unplugged the relays and tried again and it still did it,also i turned the motor over buy hand to make sure it wasent seized or the starter wasent seized
https://www.sau.com.au/forums/topic/199975-gtr-wont-start/#findComment-3560977
