Make: Nissan Skyline R33
Model: R33 GTR
Milage: 67,000 km
Transmission: Manual
Colour: Silver
Complied? Yes
Currently registered? Yes, Rego till Oct' 08
Price: Now $24,500 ONO (Price dropped from $26,000)
Contact: 0402 941 676
Comments / Modifications:
Car is very clean and never been trashed, boosted, or raced and is mechanically perfect and has been a pleasure to drive.
Modifications:
Cosmetic Mods
o Genuine Nismo 400R front lip
o Genuine Nismo 400R Side Skirts
o Nismo Rear Pods
o Razo Pedals
Performance Mods:
- HKS twin air intake pods (with piping to AFM)
- Kakimoto Full Mega N1 Stainless Steel Cat-back exhaust (Silencer Included)
- FET Turbo Timer
Additional Notes:
- Tires are Bridgestone Grid III with lots of tread on all 4 wheels
- Security Alarm System
Price is negotiable
I will get some more pictures of the car if required
Images:
Edited by RJ45
  • 2 months later...
Attached are interior pics.
I have some engine bay pics, however i can't seem to find it on my computer.
Can assure the buyer that the throttle intake manifold's black paint is all still there. None of that those ones that's thrashed and bits of paint missing.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
