PRICE DROPPED
Hey people,
This car is currently in South Australia
I'm have decided to part with my beloved manual R34 Gt-t 4 door. I've owned in for nearly 3 years and i am the first owner in Australia. The car is in immaculate condition you will not find a cleaner more well looked after example anywhere! The car is serviced every 5000kms with only the best of the best, such as redline oils etc and is garged every moment it is not being driven, is washed weekly and polished monthly. The car is driven very very rarely. I bought the car stock, all mods have been done in the last year. All mods have been professionaly fitted by high quality SA work shops such as Doyle crash, Exhaust technology, JAZMAC performance, Adelaide Pro Sound etc. This car is a dream to drive and will not disappoint even the fussiest buyer. Anyone who knows me knows haw particular i am about modifying cars and i have not spared an expence on this one. There are probably a few bits and pieces i have forgoten in the list below.
Car : Nissan R34 4 door Skyline GTT
Year: 1998 (dec)
Colour: Platinum Silver
Trans: 5 speed manual
KM: 65000 genuine kms (yes genuine)
Body:
Factory Xennon lights
Customised Nismo Aglis Front bar
Genuine East-bear sports lower lip
Nismo Side skirts
Nismo GTR style Rear lip
Rear gaurds lipped and slightly rolled
Clear side indicators
20%tint all round
Ultra white parking globes
Wing removed holes filled and whole boot repainted
Rear badges shaved (as above)
Engine:
RB25DET Neo
Custom front mount intercooler (600 x 300 x 80)
Custom intercooler piping (runs back through the stock holes)
Custom 3 1/2 inch Exhaust Technology exhaust, dump, front pipe and tail pipe with 3 1/2 inch high flow cat
Jun BL rear muffler with twin jap flutes
Nismo Radiator guide
Custom matt blue engine cover
Trust POD filter
Silicon hosing throughout
Dyno tuned computer
Drivetrain:
extreme single plate clutch
lightened flywheel
Manual conversion using 28000kms genuine r34 gearbox and all genuine r34 wiring loom, interior pieces, pedals etc.
Redline Shockproof oils
Wheels
Genuine 19 inch lenso S7 modify wheels 19x8 +30 all round
Tyres have 75%
225/35 front
235/35 rear
Custom hubcentric 15mm spacers (front)
Custom hubcentric 25mm spacers (rear)
Suspension
ISC Coilovers all round 10kg front 8kg back
Front strut brace
Interior:
Blue led dash light conversion
Tripple gauge centre unit with blue led conversion
all the standard R34 gtt goddies
Stereo:
Pioneer 9250 source unit
Factory option 8 speaker sound system (bose)
Bose front spilts
Bose rear splits
Factory Amplifier
2 Channel Magnat amplifier
4 channel Crossfire amplifier
2 x 10 inch DB+ subwoofers
Custom boot install using fibreglass sub box trimmed in grey vinal, fake floors and walls trimmed in grey velour, custom JDM embossing, perspex amplifier housing and blue neon lighting
As you can see from the pictures it's not your average r34, lots of time and money have gone into this car making it something that stands out from the import crowd. Has rego untill MAY 2008.
If interested please PM me to arange something.
PRICE DROP
Asking Price $27,000 ono Now $25900 ono
Sean
Edited by mxtcy
https://www.sau.com.au/forums/topic/200008-r34-gt-t-manual-4-door/
  • 4 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
