hello all..
im new to sau, but not to forums so i know to search before i post.
i didnt find any answers so i was wondering what types of plugs i can use on my rb25det its just running stock boost.
what have u used and what did u prefer??
cheers dan
https://www.sau.com.au/forums/topic/200038-spark-plug-types-rb25det/
are you after model numbers, or just types of plugs, ie. copper/iridium?
i used NKG copper plugs in my 33, and in my gf's stag, model number is BCPR6ES. :yes:
hey i need new plugs for my 32 and was thinking going down the copper path..if u dont mind me asking how much r they each and how long do they last..as ive herd u have to change them more often than say the platnium or iridium ones but they give a better spark as copper is a better conductor of electricity
copper ones are about $3-4 each, but only last about 5,000 - 10,000km, however they do give the best spark.
then you have iridium which are about $30-40, last 50,000km? and give a slightly weaker spark
and then there is platinum, no idea on price, but they last about 100,000km and give a weaker spark again.
i've only ever used copper, however i'm contemplating iridium as the rear 3 plugs on my legnum need the plenum removed (not as hard as it sounds though).
coppers are meant to last 15000km
irridiums are meant to last 90000km but rarely do without trouble.
and yer copper is not recomended for forced induction but alot of people say thats not true..
i have used copper in all my cars de+t and everything they are ok but dont last long.
i have found irridium to be a little better when the car is running hot, otherwise i havnt noticed any difference.
copper are $3.50 each
irridium are $20 each
ps i should have known it would be the same scenario as my ca..
but thanks guys help is much appreciated :yes:
oh and i was also wondering on what model number people had tried out and what the results were..
i know for a higher boost application the bcpr7es11 is recomended for the different heat etc..
thanks to the guy who pmed me also :P
Edited by MR fujiwara
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
