If anyone has a bolt on atmo BOV that is in good working condition for an R33 (whether it be on or off your car, i can do all the work if needed) that i can try to confirm my bov is stuffed it would be greatly appreciated.
Has to have a bolt on flange to suit standard pipe to make things easier
I can meet up with you. Im in bankstown area but willing to travel up to half hour say
so if anyone can find it in the goodness of there heart to help me out id appreciate it
hey man, i got an apexi one on my rb20det.
if its the same flange type i could possibly meet up with ya during the week. but i wont take anymoney.
im from auburn. btw you know what your doing? i dont wana buy a new bov.
cheers, issa.
i have a stock one that i can use too but problem is my atmo is fluttering no matter how much or little i adjust the spring and i think its got a prob.It used to only make the blow off noise but now it wont completely.
I have used the stockie and all is good (recirc connected) but want to make sure its the atmo bov before i dump it
issa pm sent
hey con, sorry about loosing your gasket. was nice meeting ya...
btw i still think its the noise of your BOV, i was thinking if you take your air box off, and get someone to rev it and see if air's coming from the air filter not the bov.
if you need help anytime man you got my number. gimme a buzz.
cheers, issa.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
    • I don't know the answer to this, but did you have a look at the parts diagrams on amayama.com and see what they list around it for your car? As an example this should be it on my car. That's how I would check for required clips and things like that. But, I take no responsibility for you ending up with a box full of random OEM hoses, washers and clips after going down that path a few times. This definitely has never happened to me
