  • Replies 112
Posted Images
You in luck! I just took my car apart so I can put a stock RB25 in it and sell it, so the manifold is off. I'll try to remember to get a pic soon. It's been "modified" a bit for twin wastegates (don't ask) so it's a little different than normal, but only where the wastegate runners are concerned. If I don't post anything up in a day or so, feel free to PM me and remind me.
They are Greddy knock off's BTW---it's just they are made with a lot better materials than the normal china knock offs of even the greddy mani itself. 3mm 321 stainless. That's why they don't crack. Heavy SOB's.
I think "imlate" has a pair of 6Boost low mount manifolds.
ur right - he posted a pic a few mths ago when i was considering this mod. 6boost have discontinued making them though, as i was informed when i emailed them direct in qld
does etm have a website?
hay i think you are on a winner here i had a look at them, 321 stainless and 3mm thick and they have low mount what i wanted,ceramic coated it and it should be good.
you have found my solution i think,ive been looking at jap ones from $1500-2100 but they all are 304 and 2mm thick, finally something im willing to try.
Dont you have ported standard manifolds Marko? Do you feel they are holding you back at all?
a pic of the manifold
I was there the day he took that pic. There was a japanese guy that overfilled his tranny with fluid and it was leaking all over the place. Scott (the owner of the shop that sells those mani's) put the thing up on the lift, , drained some fluid, put it in 5th gear, and put a heavy hunk of metal on the gas pedal for like 5 minutes to see if he had indeed, found out the reason for the tranny fluid all over the place. That was thr problem, and then I noticed the manifold glowing! That one is a side mount, but I've made my top mount glow like that on several occasions. It's much more dramatic at night.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
