bnr# is trying his best to confuse us. like the good sir ronin has pointed out cusco don't make adjustable front upper arms for 32 GTR, but they may do for 33 GTR. I can't remember off the top of my head (they have a different upright and different upper control arm to 32 GTR). it's beside the point anyway as the original poster is asking about 33 GTR and Rear.
if we are talking rear then you can't go past the cusco ones. top quality, very nice rod ends. good price.
Hi, Can anyone recommend good adjustable upper control arms for the rear of a GTR R33?
Cheers
Bill
As most guys know, I am not a big fan of using sphercial bearings in a road car. They are very harsh, add noticeably to the NVH, don't replace the outer, standard, rubber bushes, wear ouit very fast, knock like a bustard and can't be serviced or replaced, you have to buy a whole new arm. In addition, to avoid creating bump steer, you should adjust the effective length of the traction rod at the same time as you adjust the upper control arm. Hence why the Group Buy includes adjustable Whiteline bushes for both.
http://www.skylinesaustralia.com/forums/R3...tel-t87826.html
For guys who do regular track work and want to adjust the camber frequently, the Group Buy now has the option of Noltec bushes. Which allow on car adjustment of rear camber via a bolt and lock nut, similar to the front camber.
Cheers
Gary
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
