2007 Drift Fest. HyperGear TR43 powered CA18det S13.5 in car footage. The car's running 220KWs wheels on 15PSI with 695Nm of torque. (This power is not much compare to RB25 and RB26s, But it is not bad for a CA18det).
Part 1:
Part2:
Out car footage. (Its the Red S15 / S13 with black bonnet. I also included some nice sliding actions from other drivers)
Part 1:
Part2:
that falcon was going off haha, i reckon it was one of the best drivers on the course, guy wasn't exactly worried about stacking the car either.. there was a vn and a eb(?) out there as well, driving around in a group, all doing pretty well.. the falcon had some suspension work tho i rkn..
The judges were judging crappily imo ..one of the guys who got into the final's was a complete knacker and could hardly keep the back out lol
Edited by GTAAAH
not bad, he's got a few bad habits happening tho, so a few tips his way would be less straight line handbraking, as you can clearly tell that its not locking up too well, so more of a flick and handbrake to enter would be a good thing for him to start practicing
needs some more rear grip big time too, thing is skating 4th... and its a ca lol
all in all, keep up the good work
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
