I've often sat there thinking about the prices of cars - most of the people I chat online with are Aussie, US, or UK, and so I generally know pretty well the price of cars in each region. But I wanted to know more, so I went through a bunch of the worldwide Porsche 997 GT2 pages to check out prices from around the world. Real eye-opening stuff!
Full article here (with links to each reference page etc):
---> http://aussieexotics.com/2008/01/03/the-pr...round-the-world
And here's the basic stats in $AUD at current exchange rates:
$218k - US
$269k - Canada
$270k - Japan
$291k - UK
$299k - Switzerland
$316k - Germany
$319k - France
$320k - Italy
$347k - Brunei
$349k - Spain
$425k - Australia
$465k - China
$504k - Hong Kong
$594k - Malaysia
$920k - Denmark
https://www.sau.com.au/forums/topic/200081-price-of-cars-around-the-world/
On a similarish (if thats a word...) note I was in Vanuatu early last year and it was amazing how the major car manufacturers dont give a proverbial rats about safety and comfort if it isnt legislated! :down:
Try a brand new twin cab toyota hilux for example.
14 inch rims with piddly tyres
Fixed position bench seat
Non retracting seat belts
No airbags
No adjustable steering colum
Steering colum has no impact collapse
No air conditioning just a fan (just brilliant in a tropical climate driving round in the rain with fogged windscreen).
I've forgotten the full list of non existent safety and comfort accessories but the crowning balls kick is the Aus $35,000 price tag!!!
So... What you're saying is don't buy a porsche in denmark?
As far as the whacked out Denmark price goes, that is legitimate!
I've been googling and it seems Danes get taxed 180% of the car price to put a license plate on it!!!
Just google Denmark car taxes to look stuff up yourself and be amazed! :down:
That's ridiculous. I'm surprised the Dane's can afford to even drive a car.
Buy Porsche in US, smuggle it into Denmark and than sell it. Think i have just found a new career path.
LOL.. nah buy it from Switzerland, that way you don't have to put it on a ship.. you just drive to Denmark and enjoy some twisties on the way :O
I think we may have something here.......
I have relatives over in Czech, maybe i should make a few phone calls....
heres one for ya
Some time ago I was in Hawaii and while there i had to have a bit of a look at the cars there
So I noticed a Pontiac GTO which is pretty much the identical thing as our Monaro
Now here CV8 Monaros were selling for what 50 or 60 grand ish....Over there brand new Pontiac GTO in dealer yard going for $34000 US...Amazing when you think heres a car thats originally built in Australia,exported to the US and still sells a hell of a lot cheaper than here..We get ripped off here for many things..acohol also...Bottle of Malibu here sells for about $30 ish...over there $17 and I am told its even cheaper away from all the tourist areas....
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
