Item: pair of mono amps + 4ch, pair of subs
Age: Couple of Weeks.
Condition: Brand New.
Price: $1300
To Fit: (What car) any
Contact: Rob
Comments:
2x Pioneer PRSD1100M Mono Amps running 600RMS at 2ohm. RRP $549
2x Pioneer TSW3001D4 3000W 12" subwoofers, running 1000RMS. These run dual 4ohm voice coils, so will pull 600RMS at 2ohm out of the above monoblocks. RRP $329
1x Pioneer GM6300F 600W 4ch. RRP $329.
You can find info on these items here -
http://www.pioneer.com.au/products/car_entertainment and then just look for the product codes above.
$2000 worth of new gear.
$1300 for the lot.
Sorry guys! Sold and GOOORNE!!!!
Thank you, mystery bidder. Now give me some trader rating haha....
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
