hey just bought an uncomplied r32 1992 model stock standard and been told only needs australian tyes, child safety belt buckle and intrusion bars in the doors is there anything else i need that people can think of? if i got those 3 parts listed who knows a price sum1 could give me would cost to get complied? im in adelaide btw
https://www.sau.com.au/forums/topic/200108-need-help/
if its 1992 model its either brought in as race use only, in which you CANNOT comply it, or it has to be imported through a RAWS workshop, who do the compliance work....
I sure hope you haven't bought a race only vehicle thinking it could be complied....
did you get any paperwork when you bought it??
compliance for sevs vehicles is usually minimum $2500
https://www.sau.com.au/forums/topic/200108-need-help/#findComment-3565645
you can get quotes for basic compliancing,they do vary a bit.they will give you just the basic compliance checklist that is complusory and will cost lest 2 or 3 k.eg.the cat conversion is dear...they will only change brake pads and other needed repairs if needed and you tell them to do it.
https://www.sau.com.au/forums/topic/200108-need-help/#findComment-3565655
It CAN be complied if it's manufactured in June '92 or later. Check the VIN to see what month it was made in.
Other than that, it can't since Nissan brought in those models themselves from mid '91 until mid '92.
who holds the import approval?
1992 r32 ?
your screwed if you want compliance .it can NOT be complied for road use
if its a 1992 australian delivered skyline all it needs is to be roadworthy and pit passed
https://www.sau.com.au/forums/topic/200108-need-help/#findComment-3566522
a 1992 R32 should have side intrusion bars in the doors already.
It has to be complied by a RAW under the SEVS scheme. If its been in the country for over a year you might not be able to comply it. For it to be in the country already a RAW must have its paperwork, so your first job would be to transfer that paperwork from the RAW that imported it to the RAW that you choose to comply it.
Unless as posted previously its a race import... in which case you can't road register it anyways.
Best bet is to ring DOTARS and run the VIN number by them to see who holds the paperwork for it. If they say "that car was meant to be destroyed or re-exported a while back" well... heh good luck with that.
https://www.sau.com.au/forums/topic/200108-need-help/#findComment-3566561
correct, Nissan brought in the R32 GTR only, but that doesn't matter. It's just the R32 part that matters, so the ruling applies to all R32's, regardless of whether they're GTR's or GTS-T's. From chassy number (R32 GTS-T) HCR32 271123 onwards is ok.....
took us a while to figure that one out....if you need to know the chassy numbers for non-turbos, gts-4 and gtr's, email me or give us a call....
might cost you a beer or two, haha.
david @ carizma
I thought it shouldn't matter what year the car is (unless it was brought under the 15yo rule?)
It's a gts-t and they were never brought into australia in full volume were they?
Good luck sorting it out buddy.
https://www.sau.com.au/forums/topic/200108-need-help/#findComment-3586892
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
