The Skyline and HP...... debate and comment (PLEASE NO MUD SLINGING)
Greg from Flatout karts GTiR ran a 1.4 60 footer at the plex with an exhaust change only but got to 3rd gear and the box broke.
GTRs and EVOs seem to be the only 4wds with a half decent gear box. Every time i run my GTiR i have every thing crossed hoping the box won't die even tho its the close ratio rally box.
R33s are to big to be a strip monster but they are a quickish car thats easy to live with and don't sound like water cooled VWs.
  • Replies 126
Exactly DCIEVE...... consistancy.... the R33 all with similar mods seem to be over over the shop with times.... I would love to see quicker times out of R33 (my favorite line), hense the reason of the thread....
Does anyone know that the stock turbo can flow on the r33 (eg what is its CFM - Cubic Feet per Minute of flow)......
Daniel
hahahahah steve .....
GTiR are awesome cars, love these pulsars on steriods. Is the gearbox in them the limiting factor as well. Do they run the same sr20 motor as the s13/14/15. Dont they have a quad throttle body setup?
And Steve, some of prefer the lumpy sound of the water cooled VW's over the drony/hollow princes..... ;->
Daniel
The gearbox is very weak.I,m putting a modena box in it for next season.
The GTiR motor is an SR but has a lot better head and stronger con rods etc.My GTiR is a Dakar and ran 12.7 as a standard car with a good exhaust and a totally stuffed turbo that didn't last the first pass so it only went 20ks faster from 1/2 track to the end.
Jim richards Dakar ran 12.45.
Originally posted by rob77
got enough money together to replace the clutch and gearbox? ask denver (xrw) how many gearboxes he has chewed.
None actually..
I had the 3rd/4th gear cluster replaced to fix a crunchy syncro, and the current failure isn't the gearset at all..
a circlip that retains the centre diff has come askew and gone through the feed gears for the output shaft, taking the corner off two teeth on the output shaft gear, and ten or more corner off the feed gear..
the gearset itself has no missing teeth, just semi sad syncro's, oh and a loose nut on the end of the input shaft which was causing 5th to pop out all the time..
And that was over 2 years of giving it a hammering, and a fair slab of horse power through 4500rpm side step the clutch launches..
as for AWD taking the skill out, it doesn't, unless you know how to drive you won't get a quick time, be it drags or a motorkhana, you can be quicker than someone with 3 times the horsepower if they don't know how to peddle it to begin with..
when launching the awd makes it heaps easier, dial in revs and dump or slip it. a big power, heavy, rwd skyline on the other hand i imagine would be an absolute pain in the arse to launch. i guess this isnt really driver skill, just launching ability but its makes a huge difference at the strip. i never mentioned motorkhana's, which of course come down to driver ability more than anything else.
Rob, I know bugger all, but the whole WRX gearbox thing is so overdone (not starting a shitfight but its the same thing with LS1's and oil....). Dont listen to rumours..... :)
2 or 3 very close mates have wrx's in the 12's (one with a 12.1 and should go better with a decent drive) and not one of them has had gearbox problems. One drives his very hard, the other two drive normally.
Dan is right in saying that mod for mod WRX will probably get better times (but you cant compare apples to oranges).
I'm not biased in any way either. Both are awesome cars when set up right
Cheers
Mat
The only thing making a wrx fast is the 4wd launch, I think a rolling start between a wrx and a r33 would be interesting, stock ones. I think if I had the choice between a wrx and a GTR I'd take the GTR, with the r32 being quite cheap now and I've seen 95-97 r33's from $40k.
The guy who used to work at Fremantle Bob Janes (until it closed) had a WRX that ran 12.02..... and he was telling me he has been through 2 gearboxes in that thing.
They are still awesome cars. If you really want bang for buck you cant beat a 2 litre Silvia/180... Those things fly with FMIC, exhaust and boost control.... but lack the class of a line or WRX :)
Originally posted by Strich9ine
Ben,
was that WRX white ? with goodies like FMIC, stickers down the doors and a GT wing ?
if so, he now works at rocko bob jane :)
Yeah thats him. His names Brad. Hes from down Albany i think. Has had bunnies splatted in that FMIC hehe
Dan - you started the thread by saying that everyone seems to go for HP figures and not much else and asking what else people think should be done..
By saying upgrade the turbo and the ecu you're pretty much following the crowd.. which I thought the point of this thread was to throw some new ideas in?
Cam - i think the turbo is what MOST PEOPLE touch last. Out of all the R33 out there I bet less than 5% have modified/or complete aftermarket turbos. Most would be stock.
What I'm saying( and I may not be right, its just a opinion)... Is i would buy the Garret TURBO first (after full exhaust of course), and not waste my time on safc, ecbs, massive front mounts, etc. I would do zorst and turbo first then ecu. With those mods and putting a little boost and putting a cheap fuel regulator on (i think they can be had for < $150) you would be into the 12's easy (even on stock ecu) - if thats what you wanted, and some suspension parts and you also have a great handler as well as a straight line monster.
I think the biggest mistake is people are trying to overcomplicate things.
So my mod path would be...
1. full xzorts
2. garret turbo
3. fuel regulator (cheap way of leaning out fuel)
Daniel
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
